Seven Psychopats...ugly messages!
thedigitalpimp
#1 Post by thedigitalpimp » Wed Feb 06, 2013 7:53 pm
Using the latest version, here is what I got:
MakeMKV v1.7.10 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC09" opened in DASPI v1.3 mode.
Optical drive "BD-RE hp BD MLT UJ240 1.00" opened in DASPI v1.3 mode.
Title #19 was added (16 cell(s), 1:50:11)
Title #21 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/1 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/3 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/5 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/6 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/7 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/8 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/9 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/10 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/11 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/13 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/14 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/15 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/16 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/17 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/18 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/19 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/21 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/22 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/23 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/24 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/25 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/26 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/28 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/29 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/30 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/31 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/32 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/33 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24/34 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #35 was added (2 cell(s), 0:03:41)
Title #39 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #41 was added (1 cell(s), 0:02:28)
Drive BD-RE hp BD MLT UJ240 1.00 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Error 'Scsi error - ILLEGAL REQUEST:MEDIA REGION CODE IS MISMATCHED TO LOGICAL UNIT REGION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '2048'
Error 'Scsi error - ILLEGAL REQUEST:MEDIA REGION CODE IS MISMATCHED TO LOGICAL UNIT REGION' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '8192'
Error 'Scsi error - ILLEGAL REQUEST:MEDIA REGION CODE IS MISMATCHED TO LOGICAL UNIT REGION' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '12288'
setarip_old
Re: Seven Psychopats...ugly messages!
#2 Post by setarip_old » Wed Feb 13, 2013 5:01 am
Hi!
1) Is this a Blu-ray or is it a DVD?
2) Is the source that you're attempting to copy a disc or is it an .ISO image file, or is it a set of files?
(You've posted in the "Blu-ray Errors" sub-forum, but the files referred to appear to be DVD-related)
#3 Post by Woodstock » Wed Feb 13, 2013 5:08 am
To quote Mike from the thread at http://www.makemkv.com/forum2/viewtopic.php?f=8&t=4050 :
This means that this particular drive is a bad choice for reading DVDs with mismatched region. Try copying these discs (as they should be rare) on another drive.
