I got "Failed to save title" error when I work with DVD. I thought it DVD issue. I use AnyDVD to backup VIDEO_TS directory to hard drive. The same error.
MakeMKV v1.7.10 win(x64-release) started
Opening files on harddrive at C:/Video/Clips/MUSIC_VIDEOS/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #0 was added (12 cell(s), 1:39:05)
Title #1 was added (1 cell(s), 0:03:58)
Title #2 was added (1 cell(s), 0:05:44)
Title #3 was added (1 cell(s), 0:04:48)
Title #4 was added (2 cell(s), 0:37:36)
Saving 5 titles into directory F:/Video/MUSIC_VIDEOS
Failed to save title 0 to file F:/Video/MUSIC_VIDEOS/title00.mkv
4 titles saved, 1 failed
Failed to save title to file
Re: Failed to save title to file
Insufficient information. See link in my signature for turning on debugging and submitting information.
With a higher level of debugging turned on, you might see information flow by about inability to read a sector on the DVD, or problems writing to the drive, etc.
Debug logging enabled, log will be saved as C:\Users\Dima/MakeMKV_log.txt
Saving 5 titles into directory F:/Video/UNNAMED_DISC
DEBUG: Code 0 at i:w}#DA0R|/'T>`zrV,_:29394321
DEBUG: Code 0 at -"_A|1>~(N9#}#QgMNv:121262325
DEBUG: Code 0 at B6:5=!lFC<nqa)4/l:U!:121262762
DEBUG: Code 119 at B6:5=!lFC<nqa)4/l:U!:29393332
DEBUG: Code 0 at 0>J'6< |lf/X4F~~]Dl[m:29398323
Failed to save title 0 to file F:/Video/UNNAMED_DISC/title00.mkv
Debug log started at Sat Feb 09 14:03:57 2013 , written by MakeMKV v1.7.10 win(x64-release)
001005:0000 MakeMKV v1.7.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Dima/MakeMKV_log.txt
003006:0000 Opening files on harddrive at C:/Video/Clips/MUSIC_VIDEOS/VIDEO_TS
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003028:0000 Title #0 was added (12 cell(s), 1:39:05)
003028:0000 Title #1 was added (1 cell(s), 0:03:58)
003028:0000 Title #2 was added (1 cell(s), 0:05:44)
003028:0000 Title #3 was added (1 cell(s), 0:04:48)
003028:0000 Title #4 was added (2 cell(s), 0:37:36)
005014:0000 Saving 5 titles into directory F:/Video/UNNAMED_DISC
001003:0020 DEBUG: Code 0 at i:w}#DA0R|/'T>`zrV,_:29394321
001003:0020 DEBUG: Code 0 at -"_A|1>~(N9#}#QgMNv:121262325
001003:0020 DEBUG: Code 0 at B6:5=!lFC<nqa)4/l:U!:121262762
001003:0020 DEBUG: Code 119 at B6:5=!lFC<nqa)4/l:U!:29393332
001003:0020 DEBUG: Code 0 at 0>J'6< |lf/X4F~~]Dl[m:29398323
005003:0000 Failed to save title 0 to file F:/Video/UNNAMED_DISC/title00.mkv
005004:0080 4 titles saved, 1 failed
005037:0204 Copy complete. 4 titles saved, 1 failed.
Application exited at Sat Feb 09 14:10:15 2013
The drive is having problems reading sectors from the DVD. Since MakeMKV wants to write an error-free copy (DVD and BD players will accept a lot of errors and work around them), it gives up on that title.001002:0020 LIBMKV_TRACE: Exception: Error while reading input
First thing to try is cleaning the disk. I like to use Pledge furniture polish, because it will fill in small scratches to let you rip disks that might LOOK OK, but won't read properly.
The log say: "Opening files on harddrive" and this is correct. I already copy VIDEO_TS directory from DVD to hard drive.
Does it fail if you read directly from the DVD? Your method of copying to the hard drive may have modified the files in a way that can't be decoded.
Yes. This is why I backup it to disk. I copy it on two different PC (Win 7 64bit and WinXP x86) using two different program - the same error.Woodstock wrote:Does it fail if you read directly from the DVD? Your method of copying to the hard drive may have modified the files in a way that can't be decoded.
OK, I'm going to try to do this in a way that won't invoke the "URL filter". Mike will want a more complete debugging file for this, which you can find out how to create and transfer by putting the following after the ".com" in the forum URL:
/onlinehelp/testdump.html
It will result in a rather large file.
- Contact:
Yes, please submit a test dump per instructions at /onlinehelp/testdump.html
p.s. posting URLs as is, without[URL] tag, will not trigger post approval as long as url starts with "http://www.makemkv.com"
