Blu-Ray failed half way through conversion
leylandleopard
Post by leylandleopard »
I have repeatedly attempted to convert UK version of Role Models with MakeMKV v1.4.11. The tracks are identified and I select only the main movie, but the process fails after aprox 13GB (whole movie 27GB) with the following message.
Saving 1 titles into directory E:/Video/Role_Models
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occured while reading '/BDMV/STREAM/00348.m2ts' at offset '3477602304'
DEBUG: Code 0 at vnG@:2Fbb-!u&/+[:121268305
DEBUG: Code 100864000 at HAp&&!3d&_UBWhT{:~:213132445
DEBUG: Code 100864000 at HAp&&!3d&_UBWhT{:~:29393654
DEBUG: Code 0 at xRz]n@;ekFmnH6Ai_Pw#:213130674
DEBUG: Code 0 at |yK#-S5x46:jiP:(T3N7:213130053
DEBUG: Code 0 at xRz]n@;ekFmnH6Ai_Pw#:121262164
DEBUG: Code 1698048 at xRz]n@;ekFmnH6Ai_Pw#:213129639
Failed to save title 3 to file E:/Video/Role_Models/title03.mkv
0 titles saved, 1 failed
Any sugestions?
setarip_old
Re: Blu-Ray failed half way through conversion
Post by setarip_old »
Seems to indicate that your original BluRay disc is either dirty or physically damaged.
Try cleaning the disc. If the problem remains, return the original BluRay disc to the place of purchase in exchange for a new replacement.
Post by mike admin »
You may also try to increase "read retry count" after cleaning the disc.
leylandleopard
Thanks for the information, looking at the disc there is a mark in the coating. I will return it.
Regards
Simon
setarip_old
You're quite welcome ;>}
ELVISPOPCORN
Post by ELVISPOPCORN »
THANKS! this solution helped me too ;>}
wolfMan
Post by wolfMan »
do blurays not manufacturer as well as dvd?? seems to be lots of problem i see im getting a bluray drive soon
