Laura -1944 new release BD failed to process BD+ code
voip-ninja
#1 Post by voip-ninja » Wed Feb 06, 2013 3:32 pm
I will send the dump file, been looking forward to this one so hopefully can rip it soon.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00" opened in DASPI v1.3 mode.
Downloading latest SVQ(s) to /Users/Jason/.MakeMKV ...
Loaded 201 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/Jason/.MakeMKV/dump_Laura_49C5D140E265CFF8.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Re: Laura -1944 new release BD failed to process BD+ code
#2 Post by setarip_old » Wed Feb 06, 2013 7:12 pm
Just curious - What version number of MakeMKV did you use?
crt1948
#3 Post by crt1948 » Wed Feb 06, 2013 8:45 pm
I have the same problem. My Blu ray of Laura just arrived (a great movie, BTW) and it failed to rip with exactly the same error indication...
"Failed to process BD+ code, please check....www.makemkv.com/svq for updated program and SVQ files."
I am minimally tech savvy and don't know what a SVQ file is.
Any help would be greatly appreciated. Other Blu rays and SD DVDs have ripped recently with no problem. I use Vortexbox, which incorporates makemkv, and have the latest version of their software.
Thank you.
voip-ninja
#4 Post by voip-ninja » Wed Feb 06, 2013 10:40 pm
crt1948 wrote:I have the same problem. My Blu ray of Laura just arrived (a great movie, BTW) and it failed to rip with exactly the same error indication...
Thank you.
You will have to wait until they update SVQ. SVQ is the file that has the key needed to defeat the BD+ disc encryption. Periodically studios modify or update these encryption keys to try to thwart pirates, or in reality, those of us who legally bought their over DRMd discs.
voip-ninja
#5 Post by voip-ninja » Wed Feb 06, 2013 10:47 pm
setarip_old wrote:Just curious - What version number of MakeMKV did you use?
1.7.10.
The version does not (really) matter though. Every version since about 1.5 goes out to the internet for the latest SVQ files anyways.
#6 Post by Woodstock » Thu Feb 07, 2013 12:07 am
Sending the dump file mentioned above to svq@makemkv.com will help Mike get an SVQ file created for it.
voip-ninja
#7 Post by voip-ninja » Thu Feb 07, 2013 1:38 pm
Failed to process BD+ code, please check /svq/ for updated program and SVQ files
I did send it, hopefully see a fix soon.
voip-ninja
#8 Post by voip-ninja » Sat Feb 09, 2013 2:31 am
Not cracked yet. Do they normally provide a response to acknowledge that they received an SVQ error dump via email?
voip-ninja
#9 Post by voip-ninja » Sun Feb 10, 2013 5:32 am
Fixed with new SVQ file, thanks guys! Makes me glad to have registered MakeMKV some time ago, the ongoing support is great!
Rych_22
#10 Post by Rych_22 » Wed Feb 13, 2013 12:17 am
Hey so I'm completely new to posting on here but I've been reading through these posts and using MakeMKV for months to backup all my Blu-rays. I purchased the new Bond movie today and I run into the exact same problem as those with Laura. "BD failed to process BD+ code". I'm assuming its just a waiting game until you guys make an SVQ for this movie?
setarip_old
#11 Post by setarip_old » Wed Feb 13, 2013 4:36 am
@Rych22
Hi!
Sounds like a very reasonable assumption ;>}
#12 Post by Woodstock » Wed Feb 13, 2013 4:58 am
And it will remain valid up until someone submits the TGZ file generated for the movie to Mike, per the instructions generated in the status window, like voip-ninja did for this movie... ;)
setarip_old
#13 Post by setarip_old » Wed Feb 13, 2013 5:13 am
@Rych_22
Just to make sure, what is the version number of MakeMKV that you used to try to rip (I presume you're referring to) "Skyfall" (Not to be confused with "Downfall" or "Deadfall", both of which also came out on disc this week ;>})
I just used MakeMKV v.1.7.9 to make a successful full disc copy of Skyfall - so the SVQs must have been updated...
chill
#14 Post by chill » Sun Feb 17, 2013 12:10 am
setarip_old wrote:@Rych_22
Interesting, because the Linux version of 1.7.10 won't do Skyfall for me. It fails on the BD+ decode.
crowfax
#15 Post by crowfax » Sun Feb 17, 2013 1:32 am
chill wrote:Interesting, because the Linux version of 1.7.10 won't do Skyfall for me. It fails on the BD+ decode.
Is it set to update in the options and does it have an internet connection?
