Profile parsing error - specified conversion filter iss not
Hermannb
#1 Post by Hermannb » Tue Feb 05, 2013 8:28 am
I am using version 1.7.10 on a Windows 7 64-bit system. I get the following error message: Profile parsing error. Specified conversion filter (69:A_PCM/INT/LIT-> LPCMraw) is not available. I have tried it on another machine and it too gets that error. Thanks in advance for any assistance.
Romansh
Re: Profile parsing error - specified conversion filter iss
#2 Post by Romansh » Wed Feb 06, 2013 12:54 am
Post your conversion profile.
Hermannb
#3 Post by Hermannb » Wed Feb 06, 2013 8:15 am
Hopefully, this is what you want:
MakeMKV v1.7.10 win(x64-release) started
Title #0 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 55-end were skipped due to cell commands (structure protection?)
Complex multiplex encountered - 54 cells and 14482 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #2 was added (54 cell(s), 2:02:29)
Cells 56-end were skipped due to cell commands (structure protection?)
Saving 1 titles into directory M:/
Profile parsing error: Specified conversion filter (69:A_PCM/INT/LIT->LPCMraw) is not available
Failed to save title 0 to file M://title00.mkv
0 titles saved, 1 failed
This occurs soon after I click on the MakeMKV button. Hopefully, this is what you are asking for.
#4 Post by mike admin » Thu Feb 07, 2013 9:44 am
This is a known bug that is being worked on. It would really help if you can make and send the testdump per instructions at /onlinehelp/testdump.html for the title that fails.
Hermannb
#5 Post by Hermannb » Fri Feb 08, 2013 5:14 am
Will send the .tgz file following this email. below are some extra messages when I tan the *TESTDUMP* option
Debug logging enabled, log will be saved as C:\Users\Hermann Billenkamp/MakeMKV_log.txt
LIBMKV_TRACE: Test dump mode on
Saving 1 titles into directory M:/FilmsTemp
DEBUG: Code 0 at a]b[?'C40r2e~zJ:121262601
DEBUG: Code 1 at hnr1L(dcib*ej1D^29:29394528
DEBUG: Code 0 at hnr1L(dcib*ej1D^29:213130881
DEBUG: Code 0 at hnr1L(dcib*ej1D^29:29395425
DEBUG: Code 3 at hnr1L(dcib*ej1D^29:29396598
DEBUG: Code 0 at hnr1L(dcib*ej1D^29:29396897
DEBUG: Code 16384 at hnr1L(dcib*ej1D^29:29397679
1 titles saved
#6 Post by mike admin » Tue Feb 12, 2013 10:12 am
Thank you. Should be fixed in the next version. There is no workaround.
