DVD Naming
mikename
DVD Naming
Post by mikename » Tue Feb 05, 2013 6:25 pm
How can I get DVD's to automatically be named? It is annoying to have to rename all of them immediately, because I can't identify what 'title01.mkv' is later very easily.
As a feature request, many dvd's show their name, but still get named title00 or something like that. It would be nice if they defaulted to something more descriptive.
ertman
Re: DVD Naming
Post by ertman » Tue Feb 05, 2013 10:25 pm
You will need to access the preferences for MakeMkv, and then turn expert mode on. You will then have access to to naming disc (Optional) and from a drop down menu choosing the file name (Customize name for output) before clicking "Make Mkv".
This allows you to name beforehand and I have done this for TV shows and movies.
Hope this helps
Select Expert Mode
Select Expert Mode
naming
naming
(Optional)
Filename
Filename
mikename
Re: DVD Naming
Post by mikename » Wed Feb 06, 2013 3:49 pm
Neat. You would think this would be something there by default. Thanks!
NutFlush920
Re: DVD Naming
Post by NutFlush920 » Sun Feb 10, 2013 3:25 am
So, doing this do you always leave the profile as Default?
paulster
Re: DVD Naming
Post by paulster » Sun Feb 10, 2013 8:52 pm
Yes, unless you want to specify a profile that does something special with the output (e.g. converts audio tracks to FLAC).
If you want it to behave normally then just leave the profile set to Default.
NutFlush920
Re: DVD Naming
Post by NutFlush920 » Sun Feb 10, 2013 11:48 pm
Cool, thanks for the info. Been using for a long time and never bothered with it. Even paid already.
