Unable to use Backup
dachnik
#1 Post by dachnik » Sun Feb 03, 2013 9:56 pm
I am new to BD, and new to MakeMKV. I'm trying to backup a BBC blu-ray 2-disc television show.
MakeMKV loads the blu ray disc fine (see image below), but when I try to backup, it won't even open the disc.
Does anyone have any idea why this would happen?
On a lark, I downloaded a trial version of fab, and it was able to open, decrypt and copy the entire disk to my drive, so I don't think it's a problem with my external BD optical drive, or the BD disk itself...
Thanks for any input!
Backing up disc into folder "/Users/xxxxx/yyyy/MakeMKV/backup/MADAGASCAR_D1UK"
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/META/DL/BD_LRG.jpg' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00126.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00129.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00132.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00133.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00134.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00135.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00136.clpi' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00120.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00124.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00126.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00117.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00118.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00127.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00128.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00129.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00130.mpls' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Unit_Key_RO.inf' at offset '0'
Backup failed
Re: Unable to use Backup
#2 Post by Woodstock » Tue Feb 05, 2013 3:48 am
The debug log looks like your operating system was preventing MakeMKV write access to a resource. There is a topic on this exact subject in the Mac OS X section from 2011, where it is suggested that a device on the USB bus isn't getting sufficient power, but that was never confirmed.
I have seen this in other applications, where USB devices are fine individually, but try to access two of them at the same time, and they overtax the power from the computer, and one or both go off-line. Switching to an EXTERNALLY POWERED hub always fixed those.
dachnik
#3 Post by dachnik » Tue Feb 05, 2013 7:29 am
That seems very logical, except that my Blu Ray burner, a Matshita BD-MLT UJ-220V comes with TWO USB connections - one for data, the other devoted entirely to giving power to the drive. Both USB connections are recognized properly in the Mac OX X system report. And as I mentioned above, this same blu ray disc ripped from the same drive on dvdfab without incident.
Could it be that MakeMKV makes an inordinately high (much higher than other programs) demand on power from a Blu Ray drive?
dachnik
#4 Post by dachnik » Tue Feb 05, 2013 8:27 am
I have made a few more attempts this morning, with the same blu ray, with the same result.
I've attached below the entire MakeMKV_log.txt.
My gut is telling me there is something with this BBC disk, using AACC v19 and encoded in VC1 interlaced that MakeMKV can't deal with.
To test that, I'll try with a different blu ray and report back.
Debug log started at Tue Feb  5 08:13:00 2013 , written by MakeMKV v1.7.10 darwin(x86-release)
001005:0000 MakeMKV v1.7.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jimserv3/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ-220V 1.01" opened in DASPI v1.3 mode.
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:c146babb65033332:'
001003:0020 DEBUG: Code 0 at 70AYB3K>B%!G55ZJ:213137183
002014:0000 Optical drive "BD-ROM WD Virtual CD 1110 2003" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 5 at 70AYB3K>B%!G55ZJ:121268719
001003:0020 DEBUG: Code 2281701379 at -Jd7b4j$8Yc>R?t,XS:213132721
001003:0020 DEBUG: Code 2281701379 at -Jd7b4j$8Yc>R?t,XS:29393930
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/META/DL/BD_LRG.jpg' at offset '0'
001003:0020 DEBUG: Code 1 at JQtnLS E(bML=61Zt:121262785
001003:0020 DEBUG: Code 2281701379 at -Jd7b4j$8Yc>R?t,XS:213132100
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00126.clpi' at offset '0'
001003:0020 DEBUG: Code 0 at JkYs-hR8}v,cs(B*:213134400
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00129.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00132.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00133.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00134.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00135.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/CLIPINF/00136.clpi' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00120.mpls' at offset '0'
001003:0020 DEBUG: Code 0 at JkYs-hR8}v,cs(B*:121266718
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00124.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00126.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00117.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00118.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00127.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00128.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00129.mpls' at offset '0'
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/PLAYLIST/00130.mpls' at offset '0'
005050:0000 Evaluation version, 28 day(s) out of 30 remaining
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Unit_Key_RO.inf' at offset '0'
001003:0020 DEBUG: Code 0 at JkYs-hR8}v,cs(B*:121263544
001003:0020 DEBUG: Code 0 at JkYs-hR8}v,cs(B*:29396897
001003:0020 DEBUG: Code 2281701379 at 70AYB3K>B%!G55ZJ:213133917
Application exited at Tue Feb  5 08:16:50 2013
dachnik
#5 Post by dachnik » Tue Feb 05, 2013 11:37 am
I am thinking more and more that the problem I'm having with the blu ray disk not opening, is disk specific.
It's a disk from the BBC, video encoded in VC-1 interlaced, with AACC v19 protection.
I was successfully able to open another blu ray, also encoded in VC-1.
This one opened successfully, but would have taken over 24 hours to complete the creation of a mkv file. Seeing that, I canceled the operation.
The log text from this second blu ray disk - both the successful opening and never-ending mkv file creation is below.
Any ideas / input on all the errors I'm getting during the file creation process would be greatly appreciated!
Debug log started at Tue Feb  5 08:30:20 2013 , written by MakeMKV v1.7.10 darwin(x86-release)
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
DCE=A1LVgA4G/m92zkcvmq4fS6NC35gcqmrDDLhOhMqMWzvrVIYqXBSyacOjrA7bzLfNSLjxDBcRh6XaEi2HuY9clxkjqj08fOQNQTUuAn0twMc9dYd19IFZXGZBe4OxQnocFG4oPZC5WuI4bPYg/L8mqaI/18CeyLGWiQ==
002004:0000 Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A40..0020..0FF to device 'DASPI:IODASPIService:20cb218b6b984b78:'
DEBUG: Code 0 at iF#z8A%h:g:[pyu{.:213130283
DISCID=12330CA8AFD64D6951359C79170A3163172F5171
001003:0020 DEBUG: Code 1073741829 at pLu~Z|?AWelx7m{/:29393953
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
003307:0000 File 00051.mpls was added as title #2
003307:0000 File 00057.mpls was added as title #3
003307:0000 File 00059.mpls was added as title #4
003307:0000 File 00052.mpls was added as title #5
003307:0000 File 00053.mpls was added as title #6
003307:0000 File 00054.mpls was added as title #7
003307:0000 File 00055.mpls was added as title #8
003307:0000 File 00056.mpls was added as title #9
003309:0000 Title 00061.mpls is equal to title 00056.mpls and was skipped
003307:0000 File 00062.mpls was added as title #10
003307:0000 File 00063.mpls was added as title #11
003307:0000 File 00064.mpls was added as title #12
003307:0000 File 00067.mpls was added as title #13
003307:0000 File 00068.mpls was added as title #14
003307:0000 File 00000.m2ts was added as title #15
003307:0000 File 00006.m2ts was added as title #16
003307:0000 File 00017.m2ts was added as title #17
003307:0000 File 00018.m2ts was added as title #18
003307:0000 File 00025.m2ts was added as title #19
003307:0000 File 00028.m2ts was added as title #20
003307:0000 File 00031.m2ts was added as title #21
003307:0000 File 00033.m2ts was added as title #22
003307:0000 File 00034.m2ts was added as title #23
003307:0000 File 00035.m2ts was added as title #24
003307:0000 File 00044.m2ts was added as title #25
003307:0000 File 00045.m2ts was added as title #26
003307:0000 File 00042.m2ts was added as title #27
005014:0000 Saving 1 titles into directory /Users/jimserv3/Desktop/MakeMKV
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '194248704'
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:121262739
001003:0020 DEBUG: Code 0 at 4WX"VR*iq015*@\2kVBG:121261888
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:213130743
001003:0020 DEBUG: Code 94848 at 6/%|`yZ:|T_%:U2x1S.V:29393332
001003:0020 DEBUG: Code 0 at PK;+[Rx7qPyiWad-un~mY:29398323
005003:0000 Failed to save title 0 to file /Users/jimserv3/Desktop/MakeMKV/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Feb  5 11:27:01 2013
#6 Post by Woodstock » Wed Feb 06, 2013 12:25 am
dachnik wrote:That seems very logical, except that my Blu Ray burner, a Matshita BD-MLT UJ-220V comes with TWO USB connections - one for data, the other devoted entirely to giving power to the drive. Both USB connections are recognized properly in the Mac OX X system report. And as I mentioned above, this same blu ray disc ripped from the same drive on dvdfab without incident.
The first response I found with a Google search for the error message you are receiving described your situation fairly closely; two USB plugs to feed power to the optical drive, a Samsung USB slim BD drive:
mrgreen4242 wrote:OK, I think this might be related to not enough power in the drive, which is weird since it was working with the exact same setup before. This model takes two USB ports to power up, and was on a powered hub. I moved it directly to two ports on my iMac and it worked. Bummer since I am low on USB ports, so I might just try an external AC->USB power supply.
USB 2.0 ports are limited in the current they can supply to any one plug, which is why the drives have two plugs on them. Some ports won't have full power available to them if there are other loads on the system, which is why the powered hubs fix a lot of problems; when they're used with their adapters, they're SUPPOSED to be able to provide full current (half amp, 2.5w) to each plug.
If MakeMKV is trying to spin the drive at full speed, that would draw more current, but it shouldn't be a lot.
