First of all, MakeMKV is incredible, and I will happily pay once it's ready. I've ripped a number of disks without any glitches, but I've had some real problems with Battlestar Galactica - The Plan.
MakeMKV works just fine, but the resulting file is pretty effed up on my system.
- In Handbrake, I get: "Scanning title 1 of 1...", then "No Valid Source Found."
- In VLC, just trying to play it, I get this and then audio only: "No suitable decoder module. VLC does not support the audio or video format 'undf'. Unfortunately there is no way for you to fix this."
- Quicktime stutters and chokes, giving me *maybe* one frame every five seconds or so sporadically.
- Visualhub is just a mess anyway, but also just chokes and dies.
The blu-ray disc seems to be encoded with VC-1 instead of h.264, so I was wondering if it's just a playback issue on the Mac with Windows Media stuff so I've tried re-ripping and playing back using a plethora of programs, both on Snow Leopard as well as in Windows 7 via Parallels, but it's just not doing it. I have the latest version of perian, flip4mac, MakeMKV, I've messed around with Pavtube junk (which actually works fine if I use AnyDVD HD first, which means I'd have to pay for both programs which seems like overkill if I'm just missing something simple).
Thanks for any help!
BSG - "The Plan" giving me a headache!
counter_clockwise
El Massman
Re: BSG - "The Plan" giving me a headache!
i've had a few rips that have come out in this format and experienced the same issues you have. while i've found no way of reencoding them into a more suitable format, they are perfectly playable under plex. http://www.plexapp.com if you're the kind of person that rips films then you will probably find it great for keeping them organised as well.
hope this helps,
marc
hope this helps,
marc
counter_clockwise
That's a good point, and I'll take what I can get, but I'm still hoping I can manage to convert them to an iTunes friendly format. Plex sure is pretty but it's a little buggy, it seems.
On another note, I'm thinking of buying the complete BSG series on blu-ray, but I wonder if anyone has successfully ripped any of those disks? It'd be a shame not to be able to digitize them.
please run http://mediainfo.sourceforge.net/en on this file and post the results here.
counter_clockwise
General
Complete name : /Users/XXXXXXXX/Movies/Battlestar_Galactica_The_Plan/title01.mkv
Format : Matroska
File size : 25.4 GiB
Duration : 1h 51mn
Overall bit rate : 32.6 Mbps
Encoded date : UTC 2010-01-11 16:37:12
Writing application : MakeMKV v1.4.9 beta darwin(x86-release)
Writing library : libmakemkv v1.4.9 beta (0.7.7/0.8.1) darwin(x86-release)
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 1h 51mn
Bit rate : 30.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.612
Stream size : 23.7 GiB (93%)
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 51mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.17 GiB (5%)
Title : 3/2+1
Language : English
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Text #2
Format : PGS
Language : Spanish
Text #3
Format : PGS
Language : French
Menu
00:00:00.000 : en:Chapter 00
etc...
Figured you didn't need the entire chapter listing. Hope it helps!
Format : Matroska
Duration : 1h 51mn
Video
Format : VC-1
Codec ID : WVC1
Duration : 1h 51mn
Resolution : 8 bits
Colorimetry : 4:2:0
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 51mn
Title : 3/2+1
Language : English
Text #1
Format : PGS
Language : English
Text #2
Format : PGS
Language : Spanish
Text #3
Format : PGS
Language : French
Menu
etc...
starburst
Great tool ; thankzzzz mike!mike admin wrote:please run http://mediainfo.sourceforge.net/en on this file and post the results here.
