MakeMKV idles on Kaamelott DVD
madmox
Post by madmox »
Hello everybody,
I recently decided to rip all of my six seasons of Kaamelott (french TV show) from DVD. I successfully ripped all the 6 seasons but the 1st DVD of the 2nd season. I am using MakeMKV 1.7.10 x64 for Windows.
I tried different things:
- Selecting everything (video track, audio #1 (AC3 2.0), audio #2 (AC3 5.1), subtitles): title0 fails to save after a very short time (see log file MakeMKV_log_1.txt) ;
- Selecting all but the subtitle: title0 grows until approx. 140 Mo then stops, MakeMKV progress bar stops growing, but consumes more RAM until it reaches a few hundreds Mo (see log file MakeMKV_log_2.txt) ;
- Selecting only the video track: title 0 is saved OK but contains only half of the video (EXACTLY half of it: 25 episodes on a total of 50) ;
- Doing the same thing with AnyDVD HD launched: same result ;
I can rip the DVD by copy/pasting it from Windows explorer to my computer and it plays perfectly fine with VLC. But the VOB files seem to have strange length attributes and play badly when opened individually (although it works fine when opening VIDEO_TS.IFO). If I try to make the mkv file from the folder structure on my computer, I get the same result. I even tried using FixVTS on the folder structure on my computer without more luck. I also tried cleaning the DVD...
With a different program (DVDfab) I can rip the DVD to MKV but the audio suffers a progressive delay (from 0 to 1.5 sec after 3 hours of runtime), and I just can't do anything about it.
BUP and IFO files are all stricly identicals in size and content.
I attached 2 log files of my 1st & 2nd tries (ripping everything then everything but the subtitle track). I had to stop the process after a while for the 2nd though, as it seemed to hang.
I can link a Test Dump file if requested but it may require me some time (and I can only do it if it works on Windows).
MakeMKV_log_2.txt
(5.01 KiB) Downloaded 852 times
MakeMKV_log_1.txt
(1.17 KiB) Downloaded 808 times
setarip_old
Re: MakeMKV idles on Kaamelott DVD
Post by setarip_old »
Perhaps too obvious, but you haven't stated whether you've tried cleaning both the disc and your reader/burner.
If you have, it would seem that you have a damaged disc - and, if possible, return it to the place of purchase in exchange for a new replacement disc...
Post by mike admin »
madmox wrote:I can link a Test Dump file if requested but it may require me some time (and I can only do it if it works on Windows).
Unfortunately that's the only way. Please do a test dump for the title that fails and send per instructions at /onlinehelp/testdump.html . Please put a link to this topic in email as well.
madmox
Post by madmox »
Ok, I uploaded a test dump file and emailed the link at support@makemkv.com (http://www.mediafire.com/?jxcu780m2v44as1).
As stated in my first post, I tried to clean the DVD with no success. Recently I tried to clean the disc burner, same result.
It seems a bit strange that another software (DVDfab) succeeds (minus the audio progressive delay) in ripping the DVD to mkv if the problem originates from the disc. I also get the audio lag with the 2nd DVD of the same season with DVDfab, whereas MakeMKV has no problem with this one.
Anyway, I know DVD wear can produce strange behaviors with rippers, so I just wait for a response from the support team.
setarip_old
DVDFab was, and may still be, notorious for invisibly skipping over disc errors (replacing them with zeros, IIRC). Many times this results in a viable, but less than perfect backup.
Other similar programs do not skip errors...
tokyis
Post by tokyis »
I have the exact same problem with the same disc, I had to rip using dvd decrypter with 0 retries and ignore read error, VTS_02_1 was unreadable by most apps I tried, only cloneDVD2 was able to somewhat fix it using some kind of voodoo, this vob now works, I just have the first chapter twice as long as it's supposed to be, first half being black with audio and second half being the actual chapter with audio in sync. I'll just have to cut a few minutes at the beginning when transcoding.
I should mention the dvd is new and perfect (physically anyway), it's interesting to note that it's made by warner bros thou.
christophe_y2k
Post by christophe_y2k »
hi, i open my new dvdbox kaamelott livre2 dvd1 insert for the first time the disc and go to rip it.
Have identical problem...
impossible to rip this dvd makemkv v1.9.1 x64 under linux gentoo
- fail after approx one minute....
Very difficult to know if you have the "exact same problem", without the debugging information generated by MakeMKV. It is quite likely you are having a completely different issue, give then number of versions and months that have gone by since this thread was started 2 years ago.
anothername
Post by anothername »
Four years later, and I have the same disk with what sounds like the same problem. I'm running version 1.9.3 on Linux.
Handbrake and Brasero both fail to rip this disk as well.
I'll see about making a debug log.
anothername
Debug log started at Mon Jun  8 19:56:26 2015 , written by MakeMKV v1.9.3 linux(x64-release)
001005:0000 MakeMKV v1.9.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/mark/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003019:0000 Cells 2-2 were skipped due to cell commands (structure protection?)
003019:0000 Cells 4-3 were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (50 cell(s), 3:03:51)
003010:0000 Can't locate a cell for VTS 2 TTN 2 PGCN 2 PGN 2
Title skip vts=2 pgcn=2 hash=75DF3D38FCDCD85D
005014:0000 Saving 1 titles into directory /home/mark/Videos/KAAMELOTT_II_DVD1_F90B
001003:0020 DEBUG: Code 0 at xi.cTD!c*>'hN,^rjKhSG(k:213130122
004007:0010 AV synchronization issues were found in file '/home/mark/Videos/KAAMELOTT_II_DVD1_F90B/title00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 0:03:46.144 with duration of 32ms : broken timecode, apparent audio skew is -226.144s
004047:0010 AV sync issue in stream 0 at 0:03:46.200 : video frame timecode differs by -226.2s
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file /home/mark/Videos/KAAMELOTT_II_DVD1_F90B/title00.mkv
005004:0080 0 titles saved, 1 failed
anothername
I'm afraid that I get the same result on 1.9.4
Isn't it weird that they would have a successful exploit on just one disk out of a whole set?
Debug log started at Sun Jun 14 09:10:56 2015 , written by MakeMKV v1.9.4 linux(x64-release)
001005:0000 MakeMKV v1.9.4 linux(x64-release) started
004008:0010 AV sync issue in stream 1 at 0:03:46.176 with duration of 32ms : broken timecode, apparent audio skew is -226.176s
tokyis
Post by tokyis »
Same issue, same disc, on 3 different drives.
Debug log started at Mon Dec 14 22:14:27 2015 , written by MakeMKV v1.9.7 win(x64-release)
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\kyis/MakeMKV_log.txt
005014:0000 Saving 1 titles into directory //blackhole/Backups/BluRays/KAAMELOTT_V2D1
004007:0010 AV synchronization issues were found in file '//blackhole/Backups/BluRays/KAAMELOTT_V2D1/title00.mkv' (title #1)
004008:0010 AV sync issue in stream 2 at 0:03:46.176 with duration of 32ms : broken timecode, apparent audio skew is -226.176s
005003:0000 Failed to save title 0 to file //blackhole/Backups/BluRays/KAAMELOTT_V2D1/title00.mkv
Application exited at Mon Dec 14 22:22:48 2015
Kaamelott_V2_D1_IFOs.zip
IFO Files
(67.77 KiB) Downloaded 739 times
MakeMKV_log.txt
Log
(1.62 KiB) Downloaded 766 times
