since I got my external LG Bluray burner about 1 1/2 week ago, I am currently evaluating all those ripping solutions available including MakeMKV which is essential the tool I want to have because of Linux support
Most of the BDs I have been playing around were ripped perfectly with MakeMKV. There is just a strange behaviour I have run into on specific BDs of my collection. I am unsure what the reason for this behaviour is.
MakeMKV starts ripping the BD, slows down to something like a few hundred kB a second and then dies. MakeMKV on Win7 x64 does not play nicely. The console app dies without I am able to kill it in the task manager. Under Linux (Xubuntu 11.01 x64) I get a somewhat identical behaviour but more output. MakeMKV show SCSI errors for certain sectors an I also see I/O errors in my dmesg like that.
[14362.844278] sr 7:0:0:0: [sr1] Device not ready
[14362.844293] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14362.844306] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14362.844319] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14362.844336] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 5d 9c 00 00 3c 00
[14362.844361] end_request: I/O error, dev sr1, sector 39679600
[14362.847910] sr 7:0:0:0: [sr1] Device not ready
[14362.847925] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14362.847937] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14362.847950] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14362.847966] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 5d d8 00 00 3c 00
[14362.847991] end_request: I/O error, dev sr1, sector 39679840
[14362.852666] sr 7:0:0:0: [sr1] Device not ready
[14362.852681] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14362.852693] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14362.852707] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14362.852724] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 5e 14 00 00 0c 00
[14362.852750] end_request: I/O error, dev sr1, sector 39680080
[14363.496454] sr 7:0:0:0: [sr1] Device not ready
[14363.496470] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14363.496482] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14363.496495] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14363.496511] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 71 19 00 00 03 00
[14363.496537] end_request: I/O error, dev sr1, sector 39699556
[14363.539800] sr 7:0:0:0: [sr1] Device not ready
[14363.539816] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14363.539828] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14363.539841] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14363.539858] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 71 19 00 00 01 00
[14363.539884] end_request: I/O error, dev sr1, sector 39699556
[14363.629151] sr 7:0:0:0: [sr1] Device not ready
[14363.629166] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14363.629178] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14363.629192] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14363.629208] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 71 19 00 00 01 00
[14363.629233] end_request: I/O error, dev sr1, sector 39699556
[14363.673647] sr 7:0:0:0: [sr1] Device not ready
[14363.673662] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14363.673674] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14363.673687] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14363.673703] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 71 19 00 00 01 00
[14363.673729] end_request: I/O error, dev sr1, sector 39699556
[14363.761410] sr 7:0:0:0: [sr1] Device not ready
[14363.761426] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14363.761438] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14363.761451] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14363.761467] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 97 71 19 00 00 01 00
[14363.761493] end_request: I/O error, dev sr1, sector 39699556
[14378.373459] sr 7:0:0:0: [sr1] Device not ready
[14378.373474] sr 7:0:0:0: [sr1]  Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[14378.373486] sr 7:0:0:0: [sr1]  Sense Key : Not Ready [current]
[14378.373499] sr 7:0:0:0: [sr1]  Add. Sense: Medium not present
[14378.373515] sr 7:0:0:0: [sr1] CDB: Read(10): 28 00 00 01 ff a0 00 00 01 00BluRayCopy from FreeFab was able to copy the BDs within an hour without any hickup. So I suspect the BDs having some copy protections which either "corrupt" my BD drive or make MakeMKV "die".
So far I found Predator (Hunter Edition) and any BD of the Alien Anthology Box causing such behaviour. Let me know if I need to provide more infortations.
Has anyone experienced similar things on other BDs ?
TIA,
Holger
Edit: This is a typical message of MakeMKV under Linux:
Die Aufgabe wurde erfolgreich abgeschlossen
1 Titel werden in Verzeichnis ~/Filme/Alien gespeichert
Fehler 'SCSI-Fehler - NOT READY:MEDIUM NOT PRESENT' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00985.m2ts' bei Offset '1572864'
Fehler 'SCSI-Fehler - NOT READY:MEDIUM NOT PRESENT' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00985.m2ts' bei Offset '11962368'
Titel 0 in Datei ~/Filme/Alien/Alien_t00.mkv zu speichern schlug fehl
0 Titel wurden gesichert, 1 schlugen fehl
