Read speed suddenly only 1x while ripping blue rays
na_logo
#1 Post by na_logo » Fri Feb 01, 2013 7:54 am
Hi all,
I use makemkv under WIN XP since 8 month with the current release level and had all the time a read speed of around 2x during ripping blue ray?s.
This is not much and is caused by the riplock that's build in my LG BH10LS38 firmware.
But since end of November the read speed slows downs to around 0.9x although the configuration has not been changed.
I pached the firmware to remove the riplock without bigger change. Starting with 0x the rate speeds up to 2,6x but decrease to stable 1,2x after few seconds.
I have the same behavior with other blue ray?s and older mkv releases that worked with 2x before.
Any idea how to speed this up ?
Thanks in advance......
crowfax
Re: Read speed suddenly only 1x while ripping blue rays
#2 Post by crowfax » Fri Feb 01, 2013 5:22 pm
It sounds more like the drive is dying than a configuration failure.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
setarip_old
#3 Post by setarip_old » Sun Feb 03, 2013 10:48 pm
@na_logo
Hi!
You might want to run a cleaning disc on your reader/burner. Maxell makes one that sells for about $10US...
