Punisher Warzone Fails
dvdflashbacks
Post by dvdflashbacks »
I have tried unsuccessfully to extract two different BRs. Punisher: War Zone and Universal Soldier.
No matter what I do I receive a Fail message.
Here is my log file info:
Debug log started at Wed Jan 16 16:59:40 2013 , written by MakeMKV v1.7.10 darwin(x86-release)
001005:0000 MakeMKV v1.7.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/MakeMKV_log.txt
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=LSVIdF3c7lRGuzUAZXw7vYGh4YaI0pTVspAyqKATiUrxosXYdOUYqtPNQCEPMNGNvqiMbvkJOLsWPOJgMBfywZVBa3Cd3NJUM41fKJ8YT5SI0stITqEzb0jYy375vWund7GzByCfq7On0hkg4koWgxwulBWH3lTRFg==
DISCID=0491373B51ACEE8E5B8F40E6D91C08806AFD6F17
003307:0000 File 00004.mpls was added as title #0
003307:0000 File 00003.mpls was added as title #1
003025:0000 Title #00069.mpls(1) has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003309:0000 Title 00050.mpls is equal to title 00004.mpls and was skipped
003307:0000 File 00009.mpls was added as title #2
003309:0000 Title 00010.mpls is equal to title 00009.mpls and was skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00005.m2ts was added as title #3
003307:0000 File 00006.m2ts was added as title #4
003307:0000 File 00007.m2ts was added as title #5
003307:0000 File 00153.m2ts was added as title #6
003025:0000 Title #00240.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00241.m2ts was added as title #7
003025:0000 Title #00242.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003025:0000 Title #00243.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00245.m2ts was added as title #8
003307:0000 File 00246.m2ts was added as title #9
003307:0000 File 00247.m2ts was added as title #10
003307:0000 File 00248.m2ts was added as title #11
003307:0000 File 00249.m2ts was added as title #12
003307:0000 File 00252.m2ts was added as title #13
005014:0000 Saving 1 titles into directory /Users/Desktop/BluRay
001003:0020 DEBUG: Code 1073741829 at pLu~Z|?AWelx7m{/:29393953
001003:0020 DEBUG: Code 2 at 70AYB3K>B%!G55ZJ:121268719
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00244.m2ts' at offset '3798595584'
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:121262739
001003:0020 DEBUG: Code 0 at 4WX"VR*iq015*@\2kVBG:121261888
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:213130743
001003:0020 DEBUG: Code 1854783 at 6/%|`yZ:|T_%:U2x1S.V:29393332
001003:0020 DEBUG: Code 0 at PK;+[Rx7qPyiWad-un~mY:29398323
005003:0000 Failed to save title 0 to file /Users/Desktop/BluRay/PUNISHER_WAR_ZONE_t00.mkv
005004:0080 0 titles saved, 1 failed
Thanks.
crowfax
Re: Punisher Warzone Fails
Post by crowfax »
Dirty, damaged or poorly pressed disc. Swap it for a new one.
HolgiB
Post by HolgiB »
crowfax wrote:Dirty, damaged or poorly pressed disc. Swap it for a new one.
Don't post any assumptions without physical access to the BDs and the drive which the TO uses. :wink:
I have made similar experiences with MakeMKV reporting SCSI errors on some BDs which I ripped. They were perfectly clean. They also played back fine in my BD player. Beside this I could copy the whole BD as ISO (with encrypted files of course) to my PC without errors and the DVDFab Stuff just ripped the BD fine.
@dvdflashbacks: You could try the following things:
1) Try to rip the BDs with either DVDFabs BD Ripper or AnyDVD HD. They both have trial versions which enable you to do so without paying money.
2) Try to copy all files from the BD to your HDD or simply create an ISO from it. If there are any I/O errors caused by defect media / drive, they should also show up during this process.
The results of both things described above interest me as well since I currently still have some issues with MakeMKV.
