Firewall disc - Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE
gianfri
Post by gianfri »
MakeMKV_log.txt
(39.39 KiB) Downloaded 461 times
The disc will not be read, but it works fine in a disc player.
setarip_old
Re: Firewall disc - Scsi error - MEDIUM ERROR:L-EC UNCORRECT
Post by setarip_old »
Hi!
Try cleaning the disc. If your system still can't read it, exchange it at the place of purchase for a new replacement... (PCs have different read/play requirements than do standalone players)
Sazyario
Post by Sazyario »
I'm having the same issue.
Transformers 3 Dark of the Moon
I've tried ripping 2 retail copies. Best Buy SE and Walmart 2 disc
Also tried 2 redbox rental copies. I'm going nuts.
I get the same error as in OP's title. All the Blurays identify as Transformers3_AC
Is there a work around?
I've never heard of a firewall disc. This is the first and only bluray I have ever had problems with.
setarip_old
@sazyario
Hi!
I believe the OP is referring to the movie title "Firewall"
Dec 11, 2007 – Firewall Blu-ray (2006): Starring Harrison Ford, Paul Bettany and Virginia Madsen. Firewall stars Harrison Ford as bank security expert
Sazyario
Post by Sazyario »
setarip_old wrote:@sazyario
Hi!
Oh.... But none the less I'm having the exact same error. Even the free version of DVD fab doesn't help.
groverj3
Post by groverj3 »
Had this same error on Disc 2 of The Fellowship of the Ring extended edition. Unfortunately, all my interweb-scouring led me to the conclusion that the disc was badly manufactured. Just went out and bought a new copy of the movie and the new one works flawlessly.
Not exactly great news, but I guess this sort of thing happens from time to time.
ToxicDreamz
Post by ToxicDreamz »
I'm getting the exact same error with the Across the Universe Blu-ray disc.
I've cleaned the disc thoroughly (with a disc cleaner machine), but still no luck.
Backing up the disc encrypted also does not work at all. =\
I'm getting the same error with Master and Commander. -_-
setarip_old
It seems curious that all the titles referred to in this thread are older releases - perhaps damaged or dirty, especially possible if purchased as "Previously Viewed"...
ToxicDreamz
These are both brand new out the box. :/
crowfax
Post by crowfax »
Just because a disc is new does not mean it is well pressed.
This might also be an indication that your drive is dying.
ToxicDreamz
The drive is brand new... I've copied a few other discs just fine with MakeMKV today.
crowfax
Post by crowfax »
Try cleaning the discs and give it another go.
ToxicDreamz
... I did clean them ...
setarip_old
@ToxicDreamz
Hi!
Return the discs to the place of purchase in exchange for new replacement discs...
ToxicDreamz
Yes, I plan on doing that very soon and I'll report back.
