I like how MakeMKV shows me the segment map for each title. When there are several titles which could each potentially be the one I want, I can easily compare the titles and see what segments are different.
However, what I'd really like to do at that point is just select the particular segments to rip. For example, if one title is segments 1.m2ts, 2.m2ts and 3.m2ts, and another is 1.m2ts, 4.m2ts, and 3.m2ts, I'd like to rip just 2.m2ts and 4.m2ts, compare them, and use that comparison to select the title that I want to rip.
I can see how to make a backup of the entire disk, but that's a lot of wasted time and disk space.
Is there any way to get get the m2ts files that I want?
Ripping just selective m2ts segments?
Re: Ripping just selective m2ts segments?
MakeMKV doesn't remux parts of titles or "m2ts". How many time does your system need for an entire BD title remux?
Or maybe cross reference with the AVS BDInfo db to see which title to rip?
SC
SC
- Contact:
This feature - splitting on any segment boundary - is planned for some time. It will ease a lot of pain when processing series disks, but should work for you too. Unfortunately I can't promise when it will be done.rjbell4 wrote:However, what I'd really like to do at that point is just select the particular segments to rip. For example, if one title is segments 1.m2ts, 2.m2ts and 3.m2ts, and another is 1.m2ts, 4.m2ts, and 3.m2ts, I'd like to rip just 2.m2ts and 4.m2ts, compare them, and use that comparison to select the title that I want to rip.
Yeah... if they have the info. *Someone* has to be able to figure these things out, and I like being empowered to do so myself.Smithcraft wrote:Or maybe cross reference with the AVS BDInfo db to see which title to rip?
A whole lot longer than ripping just the title. I'd need to rip the entire disc, just to double back and rip just a single title. It's not impossible, but that's annoying inefficient. MakeMKV can obviously separate out the segments when ripping; all I need is a way to view and select checkboxes for the segments, instead of for the titles.fryk. wrote:How many time does your system need for an entire BD title remux?
Thanks, mike. I look forward to it.mike admin wrote:This feature - splitting on any segment boundary - is planned for some time. It will ease a lot of pain when processing series disks, but should work for you too. Unfortunately I can't promise when it will be done.
Mike,rjbell4 wrote: ↑Mon Jan 28, 2013 2:03 pmThanks, mike. I look forward to it.mike admin wrote:This feature - splitting on any segment boundary - is planned for some time. It will ease a lot of pain when processing series disks, but should work for you too. Unfortunately I can't promise when it will be done.
I know this post is real old, but... Is there an update on this feature?
