PS3 Ubuntu with MakeMKV
pbjunior
#1 Post by pbjunior » Sat Jan 09, 2010 8:40 pm
Great job with adding HD Audio support! Without it I was not that interested before. But now that is all changed! :)
I don't own a PC BD drive, but do own a PS3 and wanted to see if I could use that drive. Ubuntu is installed and running. I was able to compile the MakeMKV source, but when I run the bin part, I get this "makefile.linux:20: *** MakeMKV is currently not available for architecture ppc64. Stop."
Any chance of this working under the PPC processor?
If not, can I use MakeMKV with the PS3 drive if I set it up as network share?
Thanks,
PBjr.
Re: PS3 Ubuntu with MakeMKV
#2 Post by mike admin » Mon Jan 11, 2010 10:00 am
you can use ps3 drive over network but it will bring no good. ps3 drive can read data but it can't read a required key precursor from the disc since it's blocked by ps3 hypervisor.
pbjunior
#3 Post by pbjunior » Tue Jan 12, 2010 4:51 am
mike admin wrote:you can use ps3 drive over network but it will bring no good. ps3 drive can read data but it can't read a required key precursor from the disc since it's blocked by ps3 hypervisor.
Thanks for the reply. I got it working after googling more.
- MakeMKV with PS3 Ubuntu BD share will not work.
- Use 'dd' and make an .iso image
- Use the .iso image in Windows with Virtual CloneDrive
- Fire up AnyDVDHD and decrypt
- Then use MakeMKV
It's extra work but it works. I'll upgrade to a BD PC drive soon. Just need to buy some time.
Thanks,
Pbjr.
pbjunior
#4 Post by pbjunior » Tue Jan 12, 2010 11:30 pm
Might of spoke too soon. AnyDVDHD gives read error from .ISO images. 1 worked, and 2 didn't. This seems to be too much work. Time to get the Pioneer BD-205 drive and be done with it.
subslug
#5 Post by subslug » Tue Jan 19, 2010 4:02 am
Playstation Media Server will basically do what your wanting to do.
