I just started using MakeMKV and I was pretty impressed with my first dvd conversion. After the disc was converted I closed the converter and went to the folder where I saved it. And found that the VLC player had in one large file. I clicked it started playing the movie, with no problems. I decided to convert another dvd, after it was finished I went to the folder. This time I noticed that it was 20 different title files. Not one like the previous movie.
Went I dragged all the files into the VLC player it started playing, with no problem. My question is there a way that the converter can convert all the titles into one file, like it did with the first movie. Or could it be the each individual dvd is different.
Until today I never heard of MakeMLV or VLC, I was pretty impressed.
Thanks.
Converting several title in one file.
Re: Converting several title in one file.
Because they don't have the same parameters, they can not be saved as one file.
SC
SC
Okay, I made a folder for all the title files of the movie and when I clicked the "open folder" it played the movie.
Thanks for the info.
