Threw in the discs for Standard Operating Procedure and Fight Club but couldn't get either title to work with the latest MakeMKV. Log is attached. Any hints?
The WD Virtual CD 070A 1030 is not the BD drive, so that error can be ignored.
AACS host certificate is revoked
- Contact:
Re: AACS host certificate is revoked
This is not disc related - for some reasons MakeMKV is unable to sned SCSI commands to your drive. Did you install any software or updates since the last time? Is there any other porgram running in background?
Hey Guys
Very new to Make MKV.
I have ripped about 20 titles and there was no problem now i am getting the AACS host certificate is revoked. I get this even on disks I have ripped without a problem before. here is my log:
Debug log started at Tue Dec 1 20:18:06 2009 , written by MakeMKV v1.4.9 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/tomeckert/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at fSxrS|A(s^T&@zxxNi2'W7V$14E:121264878
003010:000000:0000 Using direct disc access mode
001012:000000:0020 FAILURE: Code 2 at My/g>GiZ!RMU}"FdHgmP:213130582
001012:000000:0020 FAILURE: Code 0 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 1 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 2 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 3 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 4 at :Q8'ls\JRL\{9d+yfe:121261727
001012:000000:0020 FAILURE: Code 2 at My/g>GiZ!RMU}"FdHgmP:29393907
003311:000000:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:121263015
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:213132652
005010:000000:0000 Failed to open disc
Application exited at Tue Dec 1 20:19:32 2009
I also think one of my USB ports is not working now. I had just finished ripping National Treasure and then this started.
Tom
Tom
I am getting the AACS host certificate is revoked as well. However, my log looks much different:
BLADERUNNER
Debug log started at Mon Jan 11 23:06:32 2010 , written by MakeMKV v1.4.11 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.11 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/Haselby/MakeMKV_log.txt
001012:000000:0020 DEBUG: Code 0 at 5#n<HAC}5![% >~^"b;N#NZ'?,/:121265039
002014:000000:0000 Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occured while issuing SCSI command to device 'IoKit:srv_0x2c03'
001012:000000:0020 DEBUG: Code 0 at R`Cu>n~TzH/no$Wx 2;J:121262026
001012:000000:0020 DEBUG: Code 0 at 5wn1G$[b7|EJx%AY^S:121261727
001012:000000:0020 DEBUG: Code 1 at 5wn1G$[b7|EJx%AY^S:121261727
001012:000000:0020 DEBUG: Code 2 at 5wn1G$[b7|EJx%AY^S:121261727
001012:000000:0020 DEBUG: Code 3 at 5wn1G$[b7|EJx%AY^S:121261727
001012:000000:0020 DEBUG: Code 4 at 5wn1G$[b7|EJx%AY^S:121261727
002014:000000:0000 Error 'Scsi error - ILLEGAL REQUEST:SYSTEM RESOURCE FAILURE' occured while issuing SCSI command to device 'IoKit:srv_0x2c03'
001012:000000:0020 DEBUG: Code 0 at _Rh5sl#L})]vDwcMOkS:121263015
001012:000000:0020 DEBUG: Code 0 at _Rh5sl#L})]vDwcMOkS:213132721
BLADERUNNER
What type of blu ray drive are you using. I was using a lite-on blu ray burner when I was getting this message. I returned two of them not sure what the problem was. I finally switched to a LG drive that has a faster read and write speed and everything has worked great since. I'm not really sure why this was happening but it was.
Agree with Tommye1078, what brand of Blu Ray drive are you using??????? Try to stay away from Lite-On you will be OK : )~Tommye1078 wrote:What type of blu ray drive are you using. I was using a lite-on blu ray burner when I was getting this message. I returned two of them not sure what the problem was. I finally switched to a LG drive that has a faster read and write speed and everything has worked great since. I'm not really sure why this was happening but it was.
Here is my drive info:
Manufacturer: MATSHITA
Product: BD-CMB UJ-120
Revision: 1.00
It is interesting that the speed of a drive would generate a "certificate" error.
Revision: 1.00
