Problematic HD-DVDs
roadzy
Re: Problematic HD-DVDs
Post by roadzy »
mrgstiffler wrote:I know this is old but I'm wondering if there's a solution to the Riddick problem. The main feature doesn't show up in the list of titles.
i also have this problem.
bretski
Post by bretski »
Do the devs monitor this thread any more? I ask because I've found a few problematic HD-DVDs as I've been ripping my collection...wondering if they're worth reporting or not. Thanks.
Krobar
Post by Krobar »
I have the same issue with Riddick but the vast Majority of Universal releases are fine. I noticed it is particular publishers that don't work:
Studio Canal (Have 6+ none work)
BBC / 2Entertain (About Half Broken)
Weinstein (All)
Concorde (All)
A few obscure titles (Eg. UFO)
Gravelrash
Post by Gravelrash »
I am new to this stuff so please bear with me. I am just in the process of ripping my HD-DVD collection so I can access them from XBMC. When I try and play them the picture keeps freezing and there is no sound, this is when I try and play them in XBMC. I have tried to play them in MPC-HC and the symptoms are the same but if I click on filters I see there is a number of audio filters the are about five MPC Audio Decoders running which doesn't seem right to me.
The films affected are
Serenity
Full Metal Jacket
I've got another 40 to do but if someone can shed some light on this issue before I start that would be great.
Zappes
Post by Zappes »
Brothers Grimm
Concorde
Disc can't be opened
MakeMKV v1.8.3 linux(x64-release) started
Debug logging enabled, log will be saved as /home/zaphod/MakeMKV_log.txt
Evaluation version, 15 day(s) out of 30 remaining
DEBUG: Code 0 at m6<kH1=8XU);utk8S:121262164
Title #cnrdLogo.EVO has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #warning.EVO has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #antipiracy.EVO has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #black.EVO has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at tE$eoT}(c.53?2GD8 l:29395862
DEBUG: Code 0 at tE$eoT}(c.53?2GD8 l:29394574
DEBUG: Code 0 at E7fm@^hIIs$]77SLWyKc:213130743
DEBUG: Code 14 at E7fm@^hIIs$]77SLWyKc:29393332
DEBUG: Code 0 at e65k.W9F!wySX@TNWh1Mq:213130352
DEBUG: Code 0 at e65k.W9F!wySX@TNWh1Mq:121262647
DEBUG: Code 0 at :/0u`]PFR5b^hVbxrf\:121267201
DEBUG: Code 1 at sep<fAo&SQ:H>:An:121262233
DEBUG: Code 0 at Pm%Gcb<su!HluRO:121268443
Zappes
Post by Zappes »
12 Monkeys
Concorde
DEBUG: Code 12 at E7fm@^hIIs$]77SLWyKc:29393332
Zappes
Post by Zappes »
Death at a Funeral
Concorde
DEBUG: Code 0 at D&g"Djg, pv8I:29393654
ChrisWV10
Post by ChrisWV10 »
Better late than never I suppose but my 12 Monkeys disk ripped OK using MakeMKV 1.8.5 and xbox HD-DVD drive
C :)
Krobar
Post by Krobar »
C :)
I'm guessing you are talking about the USA Universal release and not the German Concorde release (?). USA release has been OK for a long time.
jimbo1
6th Sense
Post by jimbo1 »
1) Sixth Sense
2) Hollywood Pictures Spyglass Entertainment
3) Bluray MTS
4) LPCM 5.1 and DD 5.1 English
5) Video and audio playback on computer - audio format not supported on Oppo 103 (first time with that issue for a BR)
6) Operation successfully completed
Saving 1 titles into directory G:/Azureus/
Forced subtitles track #4 turned out to be empty and was removed from output file
1 titles saved
tried switching audio on my BR player as I recorded both LPCM and DD but neither plays back.
For some reason if you select both audio tracks it won't let you play either but if you only encode the DD, the oppo can play it back.
Update - not sure why but the Oppo couldn't play it again - I ended up converting with bytecopy - slightly smaller but it plays back.
setarip_old
Post by setarip_old »
@jimbo
Hi!
This thread is for posts regarding problematic HDDVDs, whereas your post appears to be regarding a Blu-ray disc...
jimbo1
Post by jimbo1 »
setarip_old wrote:@jimbo
Hi!
Whoops- My bad! THanks for letting me know.
TrevorS
Post by TrevorS »
[Just tried several times to post a problem HD DVD (U-571/Universal) to this thread and each time Firefox tell me the site has been reset! I then gradually cut back the content and it seems your system will not allow me to include the content of the debug log file, either appended to the below or in a separate post. So, I've provided all that your system will allow me to provide.]
Hi, Just read through the thread and see others have had this problem with other titles. I'm using MakeMKV 1.8.11 (just downloaded and installed) on Win7 Ultimate 64bit with an X-Box external HD DVD drive.
U-571
Universal
1080p VC-1
Eng,Esp,Fra DD+5.1 Eng DTS 5.1
Problem is that MakeMKV appears to run fine, no errors reported, but finds only the extra content (6 items), not the main feature.
-----------------SCREEN log----------------------
MakeMKV v1.8.11 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Trevor/MakeMKV_log.txt
DEBUG: Code 0 at ~E#&/2A<MU\I*@Rm4:29393953
Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #UNILOGO.EVO has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAININTRO.EVO has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAINLOOP.EVO has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #NAVY.EVO has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at A0dg=b"A%\r^%:drGC):213132491
DEBUG: Code 0 at A0dg=b"A%\r^%:drGC):121262693
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:213130559
DEBUG: Code 10 at !,+mNdHPXD/q|[j%Otd+:29393286
DEBUG: Code 0 at _GWdR$}29B7Z0`mk[0Th::213130352
DEBUG: Code 0 at _GWdR$}29B7Z0`mk[0Th::213130904
DEBUG: Code 0 at FDB&I6iaFf%5nINuZ$@:121267201
DEBUG: Code 2 at }<KN6!J%SgB[()aj:29394413
DEBUG: Code 0 at ^t3g,!!WxY^),'O:213138770
As I said, I tried multiple times to provide the content of the debug log file (copy and paste using both Editpad Lite and Win Notepad.) Hope the info I was able to provide is enough.
Thanks -- Trevor
TrevorS
Post by TrevorS »
!!! Ignore this report, I needed to clean the disc, "Forbidden Planet" copies fine! !!! :)
I read that "Forbidden Planet" had a problem so thought I'd try it. MakeMKV was unable to save the first title which just happens to be the main feature, the other titles saved fine. MakeMKV 1.8.11.
Forbidden Planet
Warner Brothers
1080p vc-1
Eng DD+5.1, Fra,Esp DD1.0
The main feature was not copied.
Title #FBI_WHVLOGO240.EVO has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #Interpol.EVO has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #intro_black.EVO has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #THINGFAWORLDN4FT1HD1.EVO has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 17 titles into directory K:/Conversions/MakeMKVvideoFiles/HD DVD/Forbidden Planet
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/HVDVD_TS/PEVOB_1.EVO' at offset '6147459072'
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:121263038
DEBUG: Code 0 at A0dg=b"A%\r^%:drGC):121261750
DEBUG: Code 3001689 at !,+mNdHPXD/q|[j%Otd+:29393286
DEBUG: Code 0 at ){&>x>,?^(N$Rt<WLL~o@:213135090
Failed to save title 0 to file K:/Conversions/MakeMKVvideoFiles/HD DVD/Forbidden Planet/_t00.mkv
16 titles saved, 1 failed
I'll now give "Cat People" a try.
That says the drive can't read the disk. MakeMKV can only ask the drive to try more times (its in the Tools->IO menu), but that rarely helps. Cleaning the disk is the first step, possibly waxing it to fill in any small scratches.
