aspect ratio tags possible?
scph9002
Post by scph9002 »
Thing is I mux bluray discs and no matter the actual movie aspect ratio the file itself will obviously always be 16:9 IE: black bars are part of the video stream.
So when i add these movies in xbmc the program says that these movies have the aspect ratio of 16:9 which is technically correct but I want xbmc to report the visible aspect ratio that the movie was shot in.
Is that possible to add some kind of aspect ratio tag in mkv's with makemkv?
leenuss
Re: aspect ratio tags possible?
Post by leenuss »
DAR is in the MKV header and is easily edited using mkvtoolnix. However, changing the aspect ratio will result in XBMC rendering the 16:9 video stream in this custom non-square pixel ratio too. Black bars will become even larger if rendered on 16:9 display.
scph9002
Post by scph9002 »
I just want to add some type of meta tag that media libraries like xbmc might read and report from in its info label, I dont wanna change the actual AR which is already perfect. In xbmc when browsing through movies it reports different info like which audio it has (truehd or dts 5.1 or 7.1) genre, studio etc etc and also aspect ratio which it reports incorrectly because the black bars is always part of the actual video stream.
Not even sure if xbmc read tags like that even if tags like that where possible though :/
Edit: http://i.imgur.com/iQfAQ.jpg
As you can see it that picture xbmc reports wrong aspect ratio. Captain America has 1.35:1 aspect ratio
scph9002
Post by scph9002 »
edit: duplicate post
Romansh
Post by Romansh »
leenuss wrote:DAR is in the MKV header and is easily edited using mkvtoolnix. However, changing the aspect ratio will result in XBMC rendering the 16:9 video stream in this custom non-square pixel ratio too. Black bars will become even larger if rendered on 16:9 display.
Right. Which is why the OP is asking for a "tag" (metadata such as "Artist", "Genre", etc.). Of course XBMC would have to be able to interpret this in order to display the information.
And I doubt MakeMKV is the app which should write that tag. It would involve letterboxing/pillarboxing detection and therefore require video decoders. Probably the best way to do this would be manually via a dedicated metadata editor.
Q-the-STORM
Post by Q-the-STORM »
I don't think there is such a tag in mkv... only way would be checking if you can edit XBMC manually...
PatHawks
Post by PatHawks »
You're looking for the crop tag; not aspect ratio.
This can be set using
mkvmerge --cropping
Like ffmpeg, which comes bundled with MakeMKV? :wink:
fryk.
Post by fryk. »
Display aspect ratio is always 4:3 or 16:9.
But you can change the pixel aspect ratio ("PAR", aspect ratio signal) with mkvmerge-gui's header editor ("Video pixel width" & "Video pixel height") or on the command line with mkvpropedit:
mkvpropedit myvideo.mkv --edit track:v1 --set pixel-width=nnn --set pixel-height=nnn
Calculate par = dar / sar.
bw001
Post by bw001 »
You can have XBMC display the correct aspect ratio by adding the info to a local .nfo file for the movie with stream details.
e.g.:
  <fileinfo>
    <streamdetails>
      <audio>
        <channels>6</channels>
        <codec>dtshd_ma</codec>
        <language>eng</language>
        <longlanguage>English</longlanguage>
      </audio>
      <subtitle>
      </subtitle>
      <video>
        <aspect>2.35</aspect>
        <codec>h264</codec>
        <durationinseconds>5704</durationinseconds>
        <height>1080</height>
        <scantype>Progressive</scantype>
        <width>1920</width>
      </video>
    </streamdetails>
  </fileinfo>
Romansh
Post by Romansh »
Is there a format reference for this?
bw001
Post by bw001 »
Romansh wrote:Is there a format reference for this?
Try here: http://wiki.xbmc.org/index.php?title=NFO_files/movies
Romansh
Post by Romansh »
That would come in handy. Thanks!
necrosis
Post by necrosis »
bw001 wrote:You can have XBMC display the correct aspect ratio by adding the info to a local .nfo file for the movie with stream details.
e.g.:
  <fileinfo>
    <streamdetails>
      <audio>
      </audio>
      <subtitle>
      </subtitle>
      <video>
        <codec>h264</codec>
        <width>1920</width>
      </video>
    </streamdetails>
  </fileinfo>
This does not work.
http://forum.xbmc.org/showthread.php?ti ... pid1477144
