Only captured a portion of Dredd Bluray
Robroy
Post by Robroy »
I've used Makemkv without issue on a number of DVD's.
I tried it on my first Bluray, Dredd and for some reason even though it completed the process, the video was only about 90 minutes of the film (even though the file size was close to 9 GB).
Am I doing something wrong?
I should add that I play files with the most current version of VLC.
I ended up getting the DVD version of Dredd and MakeMKV worked fine with it.
setarip_old
Re: Only captured a portion of Dredd Bluray
Post by setarip_old »
Hi!
The runtime of the movie is only 95 minutes. However, if I remember correctly, the disc contains both 2D and 3D versions...
There is NO direct correlation between runtime and filesize
Robroy
Post by Robroy »
Understood but there was 40 minutes of run time after I ran the program on the bluray disc. It cut off about half way through the movie.
setarip_old
@Robroy
Please clarify - Regarding the Blu-ray:
First you say:
Then you say:
