Tried 4 times to convert errors each time.
Am I doing something incorrectly?
Error log attached
The Italian Job error
Viper1
- MakeMKV_log 1_20_2013_Italianjob.txt
- (4.03 KiB) Downloaded 538 times
Re: The Italian Job error
There is a part of the disk that your drive cannot read. This could be because of a scratch, dirt, or a bad disk. If you had your minimum time set smaller, you'd probably find other titles on the disk have problems, too. Try cleaning the disk.002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '3174729728'
Personally, I clean disks with Pledge furniture polish. It doesn't "just" clean the disk. The wax portion fills in small scratches, and can make a disk (at least temporarily) readable.
Viper1
Got it.
Will try that out tonight.
