The Italian Job error
Viper1
Post by Viper1 » Mon Jan 21, 2013 9:38 pm
Tried 4 times to convert errors each time.
Am I doing something incorrectly?
Error log attached
MakeMKV_log 1_20_2013_Italianjob.txt
(4.03 KiB) Downloaded 515 times
Re: The Italian Job error
Post by Woodstock » Tue Jan 22, 2013 12:07 am
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '3174729728'
There is a part of the disk that your drive cannot read. This could be because of a scratch, dirt, or a bad disk. If you had your minimum time set smaller, you'd probably find other titles on the disk have problems, too. Try cleaning the disk.
Personally, I clean disks with Pledge furniture polish. It doesn't "just" clean the disk. The wax portion fills in small scratches, and can make a disk (at least temporarily) readable.
Viper1
Post by Viper1 » Tue Jan 22, 2013 1:11 am
Got it.
Will try that out tonight.
