Several fmkv files out of DVD
wicked76
Post by wicked76 »
good evening all,
i've just started checking out makemkv - great piece of software.
is there a way though to put an entire dvd into one mkv file and not several ( for instande main movie, director commentary, bonus work, etc. into one mkv).
many thanks in advance,
wicked76
Smithcraft
Re: Several fmkv files out of DVD
Post by Smithcraft »
If all the files have the same parameters(display resolution, audio tracks, etc) then you could rip with MakeMKV and then append the files with mkvtoolnix.
If they don't have the same parameters, then you could try to append them but, I doubt mkvtoolnix would do it.
SC
