Fie Naming
spl147
Fie Naming
Post by spl147 » Sun Dec 30, 2012 1:17 am
is it possible to not have makemkv add the "_" and the "txx" to the output file name
paulster
Re: Fie Naming
Post by paulster » Sat Jan 19, 2013 3:00 am
View -> Preferences -> General -> Expert Mode
Then you'll find a drop-down box under Properties, which allows you to see/change the filename.
Smithcraft
Re: Fie Naming
Post by Smithcraft » Sat Jan 19, 2013 8:13 am
It still adds the underscores and the suffix.
Maybe it's one of the miscellaneous improvements?
SC
paulster
Re: Fie Naming
Post by paulster » Sat Jan 19, 2013 8:17 am
I thought Mike fixed that long ago. I never use it though as I find it quicker to rename the files afterwards outside of MakeMKV.
Smithcraft
Re: Fie Naming
Post by Smithcraft » Sat Jan 19, 2013 9:21 am
I tried it with one of the Bond50 movies. I figured I'd at least name the movie so I wouldn't have to deal with renaming it when I would go through the files, but I had to rename it to remove the underscores and suffix. I tried it again with Goldeneye, I figured it being one word would make it easier, and I still had to remove the suffix post rip.
SC
crowfax
Re: Fie Naming
Post by crowfax » Sat Jan 19, 2013 5:58 pm
I don't know how you guys feel about adding another program to your work flow, but I name my files in MakeMKV and then use "theRenamer" to make them easier for media scrapers to read.
Re: Fie Naming
Post by mike admin » Sun Jan 20, 2013 5:49 am
Smithcraft wrote:It still adds the underscores and the suffix.
If you change a filename (as opposed to title name) ???
Smithcraft
Re: Fie Naming
Post by Smithcraft » Sun Jan 20, 2013 9:11 am
Yes.
SC
Smithcraft
Re: Fie Naming
Post by Smithcraft » Wed Jan 23, 2013 11:43 am
Trying it with Curse Of The Golden Flower, so I changed the name of the movie file to Curse Of The Golden Flower, and the file created by MakeMKV is Curse_Of_The_Golden_Flower_t00.mkv instead of Curse Of The Golden Flower.mkv.
SC
paulster
Re: Fie Naming
Post by paulster » Wed Jan 23, 2013 5:05 pm
It's not the name of the movie you need to change, it's the filename. Ensure you have expert mode enabled and next to the movie name is a drop down box. Click on that and select 'filename' instead of 'name'. Then you can select the output filename you want.
Smithcraft
Re: Fie Naming
Post by Smithcraft » Wed Jan 23, 2013 10:08 pm
Thanks! That is what I did.
SC
Re: Fie Naming
Post by mike admin » Fri Jan 25, 2013 6:27 am
Are you sure? This is a screen-shot from 1.7.10 - you can change file name to anything.
Smithcraft
Re: Fie Naming
Post by Smithcraft » Sat Jan 26, 2013 12:06 am
Yes, I am sure that is what I did. I typed in the desired file name and still was given a file named in the manner I mentioned.
SC
Smithcraft
Re: Fie Naming
Post by Smithcraft » Sat Jan 26, 2013 1:29 am
I know computers is hard but, I want to do this:
MakeMKV does this:
SC
Re: Fie Naming
Post by mike admin » Mon Jan 28, 2013 8:37 am
You are changing a wrong item. "Name" is a title name, embedded in MKV metadata. By default file name is derived from it, but there is a separate item called "file name".
