VanZan
Post
by VanZan » Tue Jan 15, 2013 10:50 pm
I am a noob to makemkv but I can still appreciate how good it is. I used it for the second time today with two different ambient BluRays:
Christmas Fireplace
and
Hawaii Beaches
I put the generated mkv files on a usb key and attempted to play them with xbmc. The mkv files from the first BluRay, Christmas Fireplace, played fine with no problems whatsoever. However the second BluRay has proved more difficult. The mkv files would play but, and it's difficult to describe, the visuals were all messed up. Things were bending and swirling like a kind of visualisation special effect. I thought about ripping the BluRay again but another mkv from the disc, which was basically a promo for other discs by the same company, worked fine. I'm wondering if it's some kind of security measure as previously I had the DVD of the same product, Hawaii Beaches, was a little awkward too. I ended up having to use good old DVDDecrypter for that. So is it something I did wrong or some security measure and can it be circumvented please? Sorry for the long winded post but I like to give as much information as possible. Thank you!
VanZan on Thu Jan 17, 2013 3:48 pm, edited 1 time in total.
VanZan
Post
by VanZan » Wed Jan 16, 2013 8:03 pm
Sent an email to the creator of Hawaii Beaches and he says he spent $5000 on the protection for it. Seems like bullshit to me but what do I know.
setarip_old
Post
by setarip_old » Wed Jan 16, 2013 8:39 pm
Take the few minutes to clean the disc and re-rip it ;>}
VanZan
Post
by VanZan » Wed Jan 16, 2013 8:42 pm
It's brand new mate! The six titles with the good stuff are all distorted and the crappy promo works fine so it can't be a dirty disc!?!? /hurries off to check the disc.
VanZan
Post
by VanZan » Wed Jan 16, 2013 10:09 pm
Checked the disc and it's cleaner than clean. For the first time I tried loading one of the mkv files into Handbrake and it couldn't process it at all. Is there anything I can do? Is there some alternative to MakeMKV that could defeat the protection? Thanks guys!
VanZan
Post
by VanZan » Thu Jan 17, 2013 4:21 am
I notice the codec is VC-1...is this still a problem for MakeMKV? I'm wondering if that's why xbmc can play it or handbrake process it....feeling a little silly about the thread title now.
crowfax
Post
by crowfax » Thu Jan 17, 2013 6:29 am
It's not a problem for MakeMKV, it doesn't care what codec is on the disc. It might be a problem for your playback software though.
Chetwood
Post
by Chetwood » Thu Jan 17, 2013 6:58 am
VanZan wrote:I notice the codec is VC-1...is this still a problem for MakeMKV?
Has it ever been? I had no problems ripping BDs with VC-1 (other than it's a crappy M$ codec, of course).
VanZan
Post
by VanZan » Thu Jan 17, 2013 9:47 am
Oh yes sorry folks! A long night spent messing around with rippers when it was a codec problem the whole time. Looks like I'm going to have to transcode this bitch...sigh. I know it's not a MakeMkv question but what do I use? RipBot264?
Smithcraft
Post
by Smithcraft » Thu Jan 17, 2013 11:22 am
If it's interlaced VC-1, then you would have to use StaxRip, or RipBot. I'm not sure if there are any other applications that handle interlaced VC-1.
If it's just VC-1, then you could use whatever you want.
SC
VanZan
Post
by VanZan » Thu Jan 17, 2013 11:26 am
Ok...really embarrassing silly question time....how do I tell if it's interlaced sir? BDInfo? I'd say it is interlaced since Handbrake won't accept the mkv files created by MakeMkv.
VanZan
Post
by VanZan » Thu Jan 17, 2013 11:38 am
Found a program called MediaInfo and yes it is Interlaced unfortunately..thanks mate.
robpdotcom
Post
by robpdotcom » Fri Jan 18, 2013 1:44 am
Are you playing this on a pc via XBMC? If so, I wouldn't re-encode it. Just figure out why it isn't playing correctly in XBMC and fix it.
