1.7.10 and Blu-ray
montylee
1.7.10 and Blu-ray
#1 Post by montylee » Fri Jan 11, 2013 11:44 pm
Running the beta 1.7.10 and I put in a blu-ray disk (The Princess Bride). I'm at the "Scanning CD-ROM devices" with an elapsed time of 17:23 right now and nothing else. Running a MacPro with 10.8.2 and a LG Blu-ray drive.
Re: 1.7.10 and Blu-ray
#2 Post by Woodstock » Sat Jan 12, 2013 6:54 pm
The "Scanning" display should not be there if MakeMKV found drive to read. It comes up when MakeMKV is asking the operating system about attached optical drives.
Does OS/X see the drive?
montylee
#3 Post by montylee » Sat Jan 12, 2013 8:32 pm
Woodstock wrote:The "Scanning" display should not be there if MakeMKV found drive to read. It comes up when MakeMKV is asking the operating system about attached optical drives.
OS X (10.8.2) sees the drive. It mounts the Blu-ray disk fine. I ejected it and put in a normal DVD and it also is seen by OS/X.
#4 Post by Woodstock » Wed Jan 16, 2013 10:40 pm
Not sure what to tell you - the scanning-for-devices stage should only take a second or two, if the drive is empty at program start-up, then sit there waiting for you to put a disk in. It took marginally longer when I tested it just now with a BD in the drive, before immediately popping up with the disk title.
Unfortunately, that part of the process does not seem to be logged with Debugging turned on, so we'll have to wait for Mike to see this to get assistance. But it certainly seems that OS/X is not letting MakeMKV see the drive.
You ARE running this as a user that has full hardware privileges, correct? Is the daspi driver installed?
montylee
#5 Post by montylee » Thu Jan 17, 2013 2:42 am
Woodstock wrote:Not sure what to tell you - the scanning-for-devices stage should only take a second or two, if the drive is empty at program start-up, then sit there waiting for you to put a disk in. It took marginally longer when I tested it just now with a BD in the drive, before immediately popping up with the disk title.
I am the admin. Don't know about the daspi driver--how would I verify that?
