What Titles To Check and not Check
srmsrm
Post by srmsrm » Sat Jan 12, 2013 11:11 pm
I'm new to MakeMKV.
Below is an example of the Fugitive DVD with how things were checked. Other DVD's only had one title so the choice was easy. I made no changes to MakeMKV settings.
Since I'm new to this, how do I know what titles to select? I would assume the one with 42 chapters, however, not sure about the other titles especially with one being about 1 GB.
Also, when subtitles are checked, does it mean to only show forced subtitles? I see that option from reading other messages about forced subtitles with BlueRays, but don't see that option with DVDs.
Thank you much for the help.
Shawn
Smithcraft
Re: What Titles To Check and not Check
Post by Smithcraft » Sun Jan 13, 2013 10:52 am
The 5.8 GB/42 Chapter file is the movie, the others are extras, like behind the scenes, making of, and actor profiles type of stuff.
SC
srmsrm
Post by srmsrm » Sun Jan 13, 2013 3:01 pm
SC:
Thanks for the email. So rule of thumb would be always select the title that is the largest size?
I'm just looking for some guidelines to go by as I convert my DVDs.
Any suggestions concerning when subtitles are checked, does it mean to only show forced subtitles?
Shawn
MBPi7
Post by MBPi7 » Sun Jan 13, 2013 8:43 pm
Additional Suggestion - Especially on TV shows, check i-Tunes or Wikipedia for length of movie/show and in makemkv you can see the duration of file. Some discs will have several large files to choose from. As far as subtitles unless you want other languages you can uncheck those. For true subtitle support you may need an additional app like Subler. You will find some movies have it burned in and others do not, also handbrake may drop the subtitle, while you see it in the preview of the mkv.
It would be nice if makemkv would just add an unselect/select all button or by default unselect all the checkboxes. Gets annoying on large disc.
paulster
Post by paulster » Sun Jan 13, 2013 9:38 pm
MBPi7 wrote:It would be nice if makemkv would just add an unselect/select all button or by default unselect all the checkboxes. Gets annoying on large disc.
There is one on the context menu. Just right-click and it's there.
Chetwood
Post by Chetwood » Mon Jan 14, 2013 6:04 am
MBPi7 wrote:Additional Suggestion - Especially on TV shows, check i-Tunes or Wikipedia for length of movie/show and in makemkv you can see the duration of file.
Why go on iTunes, when you can playback the episodes on your computer and check the length there?
srmsrm
Post by srmsrm » Wed Jan 16, 2013 10:11 pm
Thanks all for the feedback.
