Archer: The Complete Season 3
athanatos875
Post by athanatos875 »
Just got my copy of Archer: Season 3 today. It seems that MakeMKV cannot open the Blu-ray discs due to BD+ protection. The protection found was AACS v27 and BD+ v2012.10.
MakeMKV v1.7.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\#####/MakeMKV_log.txt
Loaded 167 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at 7,XkN!7IR."bB5P-:29400531
DEBUG: Code 0 at 7,XkN!7IR."bB5P-:29398254
DEBUG: Code 0 at 7,XkN!7IR."bB5P-:213139690
Failed to process BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at ]Sm)p=Vm9T7-A Hxv$:121265752
Saved BD+ dump file as C:\Users\#####/.MakeMKV/dump_Archer__Season_3_Disc_1_BC9315BB5B4C7A64.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
DEBUG: Code 0 at #2%nH]m+8/Nq5! Y:29396897
Does anyone else have this issue? I will provide the dump file if needed. Thank you!
MakeMKV_log.txt
Log File
(1.5 KiB) Downloaded 495 times
Dugnificent
Re: Archer: The Complete Season 3
Post by Dugnificent »
I had the same problem with both discs. I emailed the dump files as instructed, haven't heard anything back. Really annoyed at the DRM here.
crowfax
Post by crowfax »
I've also mailed in my dumps. The SVQ will be updated soon enough.
athanatos875
Excellent! I have also emailed my dumps. I have not had a reply yet, but I am sure they are working on it.
crowfax
Post by crowfax »
The SVQ file has been updated, I'm ripping mine now.
Try again!
athanatos875
Working for me too!
Dugnificent
Got both discs ripped last night. Sploosh!
