The Odd Life of Timothy Green
imahawki
Post by imahawki » Tue Jan 08, 2013 10:58 pm
I'm getting an error ripping this BD. It stops at 7% and just spits the disk out. I'm using an LG BD drive on a Mac with OSX Mountain Lion. This is the first time I've ever had a disk fail to rip.
Re: The Odd Life of Timothy Green
Post by Woodstock » Wed Jan 09, 2013 12:16 am
Follow the steps in the link in my signature - debugging information makes figuring these things out MUCH simpler! :)
(well, maybe - the signature doesn't want to show reliably... it's FAQ #8, Troubleshooting, and explains how to turn on the debugging log and what to send in to help with your problem)
imahawki
Post by imahawki » Wed Jan 09, 2013 12:44 am
Debug log started at Wed Jan 9 00:34:17 2013 , written by MakeMKV v1.7.10 darwin(x86-release)
001005:0000 MakeMKV v1.7.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/CJ/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHF" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW UH12LS29 1.00" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQkEHwEBAQIBDQAAAAAgAAAAAAAAAAA=
DCE=WLZajrgRkhSWvfjlji1RYx93AbqlHc1UYoLUyoewzTQVNvJ3h/wKS7Pjv/5eHYS7LPz7wCw3HJGP4T23EifsL/7qdrk4gchyizwDmRfbT5oXX4f6N8sXKbQCVbSqOqyja+SyQyV3uRIAUx4C+GSf7oMow6Yr5pT9vQ==
DCE=XkvG+STUubvUWgLywHdqJomlLJnHpGse9B2MWGmqCrs01QZMmXrVC+L3bTVpboiyyz4CEAkXa9f82CvCziRFYtZ6kdbuyhhMfm/Eqh+SVwKIKds2z3kLWwp4/hTE7DHQg4oCvgYW8Z17au6uIBHaK8nWv0SBsKwiXg==
DISCID=1B49EC42D3E4F9D22AABDD3494B8EA819F21854E
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00255.mpls was added as title #1
003309:0000 Title 00813.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00527.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00528.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00501.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00876.m2ts was added as title #2
003307:0000 File 00877.m2ts was added as title #3
003307:0000 File 00887.m2ts was added as title #4
003025:0000 Title #00888.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00889.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00890.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00891.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00892.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00893.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00894.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00895.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00896.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/CJ/Movies/The_Odd_Life_of_Timothy_Green
001003:0020 DEBUG: Code 1073741829 at pLu~Z|?AWelx7m{/:29393953
001003:0020 DEBUG: Code 2 at 70AYB3K>B%!G55ZJ:121268719
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2247684096'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2248015872'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2248144896'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2248470528'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2249650176'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2251948032'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2252144640'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2252273664'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '2252470272'
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:121262739
001003:0020 DEBUG: Code 0 at 4WX"VR*iq015*@\2kVBG:121261888
001003:0020 DEBUG: Code 0 at 6/%|`yZ:|T_%:U2x1S.V:213130743
001003:0020 DEBUG: Code 1099839 at 6/%|`yZ:|T_%:U2x1S.V:29393332
001003:0020 DEBUG: Code 0 at PK;+[Rx7qPyiWad-un~mY:29398323
005003:0000 Failed to save title 0 to file /Users/xxxxx/Movies/The_Odd_Life_of_Timothy_Green/The_Odd_Life_of_Timothy_Green_t00.mkv
005004:0080 0 titles saved, 1 failed
setarip_old
Post by setarip_old » Wed Jan 09, 2013 8:22 pm
I had no problem using MakeMKV to rip this Blu-ray disc...
