set subtitle flag to default = no
Is there a way to always make subtitles have the default flag set to no? Currently, all of my rips set the default flag to yes, which means subtitles are always on in my player and I have to turn them off. These are just normal non-forced subtitles. I can easily change the flag in the header editor using MKVMerge, but is there an easier way using an advanced profile?
						Re: set subtitle flag to default = no
Conversion profiles wrote:Code: Select all
ignoreForcedSubtitlesFlag - never set "forced" flag for subtitle tracks. Default - true. useISO639Type2T - use ISO 639/2T instead of ISO 639/2B for language codes. Default - false. setFirstAudioTrackAsDefault - set "default" flag for a first audio track. Default - true. setFirstSubtitleTrackAsDefault - set "default" flag for a first subtitle track. Default - true.
I would like to do this too but I don't understand how to add the option into a conversion profile I'm using below. Any help would be nice
lpcm2flac.mmcp.xml
Edit: Thanks!
													lpcm2flac.mmcp.xml
<?xml version="1.0" encoding="utf-8"?>
<profile>
    <!-- profile name - Default -->
    <name lang="eng">LPCM to FLAC</name>
    <!-- Common MKV flags -->
    <mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
    <!-- Settings overridable in preferences -->
    <profileSettings
        app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang),+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang"
    <!-- Output formats currently supported by MakeMKV -->
    <outputSettings name="copy" outputFormat="directCopy">
        <description lang="eng">Copy track as is</description>
        <description lang="ger">Track 1:1 kopieren</description>
    </outputSettings>
    <outputSettings name="lpcm" outputFormat="LPCM-raw">
        <description lang="eng">Save as raw LPCM</description>
        <description lang="ger">Als RAW LPCM speichern</description>
    </outputSettings>
    <outputSettings name="wavex" outputFormat="LPCM-wavex">
        <description lang="eng">Save as LPCM in WAV container</description>
        <description lang="ger">Als LPCM im WAV-Container speichern</description>
    </outputSettings>
    <outputSettings name="flac-best" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (best compression)</description>
        <description lang="ger">Als FLAC speichern (h?chste Komprimierungsstufe)</description>
        <extraArgs>-compression_level 12</extraArgs>
    </outputSettings>
    <outputSettings name="flac-fast" outputFormat="FLAC">
        <description lang="eng">Save as FLAC (fast compression)</description>
        <extraArgs>-compression_level 5</extraArgs>
    </outputSettings>
    <!-- Default rule - copy as is -->
    <trackSettings input="default">
        <output outputSettingsName="copy"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <!-- Save LPCM mono or stereo as FLAC -->
    <trackSettings input="LPCM-stereo">
        <output outputSettingsName="flac-fast"
        </output>
    </trackSettings>
    <!-- Save multi-channel LPCM as FLAC -->
    <trackSettings input="LPCM-multi">
                defaultSelection="$app_DefaultSelectionString,+sel:true">
        </output>
    </trackSettings>
</profile>
discoteca wrote:Code: Select all
<!-- Common MKV flags --> <mkvSettings ignoreForcedSubtitlesFlag="true" useISO639Type2T="false" />
    <mkvSettings
        setFirstSubtitleTrackAsDefault="false"
