Handbrake wont encode after makemkv
mansnake
#1 Post by mansnake » Sat Jan 05, 2013 9:25 am
Ok so this is the first time iv'e tried ripping my Blu rays and makemkv is simple enough. At the moment i'm ripping Wonders of the Solar System and want to encode with handbrake to a manageable file size for my media centre.
Once makemkv has output the mkv i open it within handbrake, i select the options i want 720p etc... then i hit the start button. It counts to 4 seconds then comes up with encoding finished and the output file is 4 Kb in size.
I've tried ripping as selected titles and complete backup but its the same results. I have the latest versions of makemkv and handbrake installed, i also installed shark007 codec pack so that i had sound when playing back my mkv's (they work fine BTW)
Am i doing something wrong?
My spec is:-
Lenovo Z580
Win 8
External Blu ray drive
This is the handbrake output before i have even clicked encode and just opened the required mkv
HandBrake 0.9.8 2012071700
OS: Microsoft Windows NT 6.2.9200.0
CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Ram: 8052 MB, Screen: 1366x768
Temp Dir: C:\Users\lewis_000\AppData\Local\Temp\
Install Dir: C:\Program Files\Handbrake
Data Dir: C:\Users\lewis_000\AppData\Roaming\HandBrake\HandBrake\0.9.8.4861
-i "C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv" -t0 --min-duration=10 -v
[09:22:38] hb_init: starting libhb thread
HandBrake 0.9.8 (2012071700) - MinGW x86_64 - http://handbrake.fr
4 CPUs detected
Opening C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv...
[09:22:38] hb_scan: path=C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv, title_index=0
libbluray/bdnav/index_parse.c:157: indx_parse(): error opening C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv/BDMV/index.bdmv
libbluray/bluray.c:1471: nav_get_title_list(C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv) failed (0000000001CC5230)
[09:22:38] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[09:22:38] dvd: not a dvd - trying as a stream/file instead
[vc1 @ 0000000001CC8B60] Interlaced frames/fields support is incomplete
Input #0, matroska,webm, from 'C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv':
Metadata:
title : Wonders of the Solar System Disc 1
Duration: 00:58:27.00, start: 0.000000, bitrate: 3072 kb/s
Chapter #0.0: start 0.000000, end 587.360000
Metadata:
title : Chapter 00
Chapter #0.1: start 587.360000, end 1242.680000
Metadata:
title : Chapter 01
Chapter #0.2: start 1242.680000, end 2041.120000
Metadata:
title : Chapter 02
Chapter #0.3: start 2041.120000, end 2843.440000
Metadata:
title : Chapter 03
Chapter #0.4: start 2843.440000, end 3507.000000
Metadata:
title : Chapter 04
Stream #0.0(eng): Video: vc1 (Advanced), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc
Stream #0.1(eng): Audio: dca (DTS-HD HRA), 48000 Hz, 5.1, s16, 1536 kb/s (default)
Metadata:
title : HRA XBR
Stream #0.2(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s
Metadata:
title : 3/2+1
Stream #0.3: Attachment: mjpeg
Metadata:
filename : cover.jpg
mimetype : image/jpeg
[09:22:38] scan: decoding previews for title 1
[NULL @ 0000000001CC8B60] Interlaced frames/fields support is incomplete
[09:22:38] scan: audio 0x2: DCA, rate=48000Hz, bitrate=1536000 English (DTS) (5.1 ch)
Scanning title 1 of 1...
[09:22:38] scan: 10 previews, 1920x1080, 25.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[09:22:38] scan: title (0) job->width:1920, job->height:1072
[09:22:38] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: C:\MakeMKV output\Wonders_of_the_Solar_System_Disc_1_t00.mkv
+ duration: 00:58:27
+ size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 25.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:09:47
+ 2: cells 0->0, 0 blocks, duration 00:10:55
+ 3: cells 0->0, 0 blocks, duration 00:13:18
+ 4: cells 0->0, 0 blocks, duration 00:13:22
+ 5: cells 0->0, 0 blocks, duration 00:11:03
+ audio tracks:
+ 1, English (DTS-HD HRA) (5.1 ch) (iso639-2: eng)
+ 2, English (DTS) (5.1 ch) (iso639-2: eng), 48000Hz, 1536000bps
+ subtitle tracks:
HandBrake has exited.
Thanks for your help!
