Hi
I've been using makemkv for a while now, for both dvds and bds. Generally i rename files in the order they are exported from makemkv.
But with some blurays (Fringe, Game of Thrones to name but two), the real order is different to the order outputted by makemkv.
While doing Fringe s4, I realised that ascending mpls number was the correct order, which saved me a lot of hassle (quick check of each episode instead of matching each one up).
Is it possible to order by mpls before applying the automatic file names?
I don't know if this would screw up or make anything else more awkward, so maybe at least a button or menu option somewhere to redo it or set a default?
Ben
series order
Re: series order
You may be interested in this previous discussion:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=1822
DaveQ
DaveQ
Re: series order
What about when they are in a random order?
Discs can be mastered in so many different and screwed up ways, that it would be impossible to make a setting for every disc.
SC
SC
