Can't find any real error message, it just doesn't seem to w
henryblake
#1 Post by henryblake » Fri Dec 28, 2012 5:36 pm
My setup is this:
OSX 10.8.2
MakeMKV 1.7.9
Mac mini (mid 2011)
Plextor Blu-Ray Reader PX-B120U (external USB 2.0)
I am new to copying BluRays, these are my first two attempts. I have been reading other peoples error reports, and then my own MakeMKV logs. However, I cannot seem to find any error messages as such, it just doesn't seem to work...
Saving Private Ryan
MakeMKV v1.7.9 darwin(x86-release) started
Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
File 01027.mpls was added as title #0
Title #00002.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01015.mpls was added as title #1
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory /Volumes/felles/Film
Failed to save title 0 to file /Volumes/felles/Film/Saving_Private_Ryan_Disc_1_t00.mkv
Failed to save title 1 to file /Volumes/felles/Film/Saving_Private_Ryan_Disc_1_t01.mkv
0 titles saved, 2 failed
Slumdog Millionaire
File 00004.mpls was added as title #0
File 00000.mpls was added as title #1
File 00018.m2ts was added as title #2
Title #00017.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00016.m2ts was added as title #3
File 00015.m2ts was added as title #4
File 00014.m2ts was added as title #5
Title #00013.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #6
File 00008.m2ts was added as title #7
File 00007.m2ts was added as title #8
File 00006.m2ts was added as title #9
File 00003.m2ts was added as title #10
File 00002.m2ts was added as title #11
File 00001.m2ts was added as title #12
Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 13 titles into directory /Volumes/felles/Film
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Failed to save title 1 to file /Volumes/felles/Film/Slumdog_Millionaire_t01.mkv
Failed to save title 2 to file /Volumes/felles/Film/Slumdog_Millionaire_t02.mkv
Failed to save title 11 to file /Volumes/felles/Film/Slumdog_Millionaire_t11.mkv
10 titles saved, 3 failed
Any ideas as to what the problem can be? The external BluRay drive is brand new, it came today.
The BluRay discs plays w/o any trouble.
Sincerely
setarip_old
Re: Can't find any real error message, it just doesn't seem
#2 Post by setarip_old » Sat Dec 29, 2012 3:34 am
Hi!
I'm not a Mac user, but I presume the following is significant regarding Macs with MakeMKV:
henryblake
#3 Post by henryblake » Sat Dec 29, 2012 8:11 am
setarip_old wrote:Hi!
I read it as being significant to improve performance (ie: speed), not to make it work pr say. But I may be wrong.
I am installing now, however, and will post back shortly with an update.
It appears the end result is the same:
Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in DASPI v1.3 mode.
Evaluation version, 29 day(s) out of 30 remaining
#4 Post by Woodstock » Sat Dec 29, 2012 10:24 pm
In the MakeMKV configuration, under Tools, General, turn on "Log debug messages".
When you start MakeMKV, it will tell you that it is on, and where it is saving the log file.
There are additional messages that should show up with debugging enabled.
henryblake
#5 Post by henryblake » Sun Dec 30, 2012 1:20 pm
The MakeMKV_log.txt reads as follows
Debug log started at Sun Dec 30 12:46:03 2012 , written by MakeMKV v1.7.9 darwin(x86-release)
001005:0000 MakeMKV v1.7.9 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/robert/MakeMKV_log.txt
002014:0000 Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in DASPI v1.3 mode.
005050:0000 Evaluation version, 28 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQEEAAADAQ==
DCE=C5DO7YZFf5ajd5sIXZEl9vs6HRYUc6U6Y3wGuHC7wpE92UykDGjn1FaCCUTRoVDJWTA41CvrmTId4yTH6P4SjvMQMHuyct2kHKYt25XHgTSOtm+zKxnm2YMwUP9yYak50o2i8OrFTfQ5QLfBpFDAbPj/arFep4Hwkg==
DISCID=F173C5A84B1783A7AB2DD89531646062AC409A34
003307:0000 File 00004.mpls was added as title #0
003307:0000 File 00000.mpls was added as title #1
003307:0000 File 00018.m2ts was added as title #2
003025:0000 Title #00017.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #3
003307:0000 File 00015.m2ts was added as title #4
003307:0000 File 00014.m2ts was added as title #5
003025:0000 Title #00013.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #6
003307:0000 File 00008.m2ts was added as title #7
003307:0000 File 00007.m2ts was added as title #8
003307:0000 File 00006.m2ts was added as title #9
003307:0000 File 00003.m2ts was added as title #10
003307:0000 File 00002.m2ts was added as title #11
003307:0000 File 00001.m2ts was added as title #12
003025:0000 Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 13 titles into directory /Volumes/felles/Film
AV sync issues in /Volumes/felles/Film/Slumdog_Millionaire_t00.mkv
AV sync in 1 at 0:11:34.112 (32ms) : 1 overlapping frame(s) dropped at segment boundary
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #7 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #9 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #11 turned out to be empty and was removed from output file
001003:0020 DEBUG: Code 8 at w:e/vNC_IHXtNqX:jvI\`j:29393999
001003:0020 DEBUG: Code 4294967295 at w:e/vNC_IHXtNqX:jvI\`j:121262141
001003:0020 DEBUG: Code 5 at w:e/vNC_IHXtNqX:jvI\`j:213130329
001003:0020 DEBUG: Code 0 at y~Xyo$0|"M&P:xOWf:121263728
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 1 to file /Volumes/felles/Film/Slumdog_Millionaire_t01.mkv
005003:0000 Failed to save title 2 to file /Volumes/felles/Film/Slumdog_Millionaire_t02.mkv
005003:0000 Failed to save title 11 to file /Volumes/felles/Film/Slumdog_Millionaire_t11.mkv
005004:0080 10 titles saved, 3 failed
005037:0204 Copy complete. 10 titles saved, 3 failed.
#6 Post by Woodstock » Sun Dec 30, 2012 4:19 pm
Are you, by chance, trying to save the output to a network location? This error may indicate that the system gave an error when trying to write a file larger than the storage location would accept, which can happen when using SMB networking (ie, Microsoft Networking).
henryblake
#7 Post by henryblake » Sun Dec 30, 2012 5:22 pm
Hm, ok. I am writing to a Buffalo NAS disk (Linkstation) - using SMB networking. I will try to rip directly to the Mac's internal drive instead and see if that works better. Will post back after testing.
henryblake
#8 Post by henryblake » Sun Dec 30, 2012 8:18 pm
And voil?! Worked like a charm :)
Thank you for helping!
#9 Post by Woodstock » Sun Dec 30, 2012 8:58 pm
This is not really SUPPOSED to happen; the SMB networking can support larger-than-4GB files, but some combinations of software report the file system of the network share as being FAT32, even when it isn't, which limits files to 4GB.
Glad it's working, though. As a test, try copying the files to the NAS with Finder. If it works, the NAS can handle bigger files, but is not reporting that capability to the Mac. If it doesn't, check the NAS for what it uses for a file format on the disk. FAT32 is the most restrictive out there, but most NAS machines will understand NTFS, Ext4, and other higher-performance file systems.
henryblake
#10 Post by henryblake » Sun Dec 30, 2012 9:36 pm
I know the NAS supports larger files than the MakeMKV produced this time, because I already have larger files on it. So I end up ripping to local disk and move the file.
henryblake
#11 Post by henryblake » Tue Jan 01, 2013 1:57 pm
This may not belong in this forum, but I will try anyway.
After I make an MKV, I want to process the file through Handbrake before I import it into iTunes. However, when I run MakeMKV with a BluRay, Handbrake doesn't seem to create a viewable .mp4 (or .m4v) file.
After MakeMKV, the .mkv file plays perfectly in VLC Player, both with a BluRay and a DVD rip.
However, after running the same .mkv files through Handbrake, only the DVD rip gives a viewable .mp4 file.
The .mp4 file from the BluRay rip doesn't playback either via VLC Player or QuickTime, and it doesn't import to iTunes.
The .mp4 file from the DVD rip plays back in VLC player and imports fine to iTunes.
I use all the same standard settings in both MakeMKV and Handbrake for both BluRays and DVDs.
Any suggestions as to how I can solve this?
I have read a couple of "how-tos" (http://lifehacker.com/5559007/the-hassl ... collection and https://forum.handbrake.fr/viewtopic.php?f=5&t=19939), but it doesn't provide an answer.
Romansh
#12 Post by Romansh » Thu Jan 03, 2013 3:33 pm
https://trac.handbrake.fr/wiki/SupportFAQ#fourgb
Please direct any further questions to the HandBrake forum.
