Abraham Lincoln Error Report
nkhan
#1 Post by nkhan » Wed Dec 19, 2012 12:38 pm
Can anyone help with the following
MakeMKV v1.7.9 win(x64-release) started
Opening files on harddrive at G:/Abraham_Lincoln_3D
Downloading latest SVQ(s) to C:\Users\Vostro/.MakeMKV ...
Loaded 161 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\Vostro/.MakeMKV/dump_Abraham_Lincoln__Vampire_Hunter_D023309F7DE376E1.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
nkhan
Re: Abraham Lincoln Error Report
#2 Post by nkhan » Sun Dec 30, 2012 4:45 pm
Anyone help
#3 Post by Woodstock » Sun Dec 30, 2012 8:53 pm
Did you submit the file it saved to support@makemkv.com yet, so it can be analyzed? Without it, there isn't much that can be done to help...
setarip_old
#4 Post by setarip_old » Mon Dec 31, 2012 7:35 am
"please check" http://www.makemkv.com/svq/%20for%20upd ... VQ%20files
NO LONGER A VALID LINK.
SEE NEXT POST!
setarip_old
#5 Post by setarip_old » Mon Dec 31, 2012 7:37 am
Click on the following link:
nkhan
#6 Post by nkhan » Wed Jan 02, 2013 11:20 pm
Sending the file now, didn't realize i had too
Thank you
nkhan
#7 Post by nkhan » Fri Jan 04, 2013 1:03 pm
What happens after i have sent in the file?
Thank you
crowfax
#8 Post by crowfax » Fri Jan 04, 2013 5:31 pm
Update to 1.7.10 and try again. Make sure the computer MakeMKV is installed on has an active internet connection and try again.
nkhan
#9 Post by nkhan » Sun Jan 06, 2013 3:34 pm
crowfax wrote:Update to 1.7.10 and try again. Make sure the computer MakeMKV is installed on has an active internet connection and try again.
I was on 1.7.10 but remove and re-install and report back
nkhan
#10 Post by nkhan » Sun Jan 06, 2013 3:40 pm
Just tried it and again and no luck
