Can anyone help with the following
MakeMKV v1.7.9 win(x64-release) started
Opening files on harddrive at G:/Abraham_Lincoln_3D
Downloading latest SVQ(s) to C:\Users\Vostro/.MakeMKV ...
Loaded 161 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\Vostro/.MakeMKV/dump_Abraham_Lincoln__Vampire_Hunter_D023309F7DE376E1.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Abraham Lincoln Error Report
Re: Abraham Lincoln Error Report
Saved BD+ dump file as C:\Users\Vostro/.MakeMKV/dump_Abraham_Lincoln__Vampire_Hunter_D023309F7DE376E1.tgzMakeMKV Frequently Asked Questions
setarip_old
"please check" http://www.makemkv.com/svq/%20for%20upd ... VQ%20files
NO LONGER A VALID LINK.
SEE NEXT POST!
SEE NEXT POST!
setarip_old
Click on the following link:
nkhan
Sending the file now, didn't realize i had tooWoodstock wrote:Did you submit the file it saved to support@makemkv.com yet, so it can be analyzed? Without it, there isn't much that can be done to help...Code: Select all
Thank you
nkhan
What happens after i have sent in the file?
Thank you
Thank you
crowfax
Update to 1.7.10 and try again. Make sure the computer MakeMKV is installed on has an active internet connection and try again.
nkhan
I was on 1.7.10 but remove and re-install and report backcrowfax wrote:Update to 1.7.10 and try again. Make sure the computer MakeMKV is installed on has an active internet connection and try again.
nkhan
Just tried it and again and no luck
