SUGGESTION: Autoplay
ldoodle
Post by ldoodle » Wed Jan 06, 2010 11:05 am
Would it be possible to add an option to prevent discs from autoplaying if MakeMKV is open.
When you're doing 10's of discs in a row, it becomes somewhat annoying to have the configured player open up when each disc is inserted.
adrian
Re: SUGGESTION: Autoplay
Post by adrian » Wed Jan 06, 2010 11:21 am
Just hold down the shift key when inserting the disc. It will prevent the autostart from running.
ldoodle
Post by ldoodle » Wed Jan 06, 2010 11:23 am
Yeah I know that trick, but it's a conscious thing you have to do :roll:
adrian
Post by adrian » Wed Jan 06, 2010 11:28 am
If you know about that trick, surely your preferred player isn't opening for every disc? :roll:
ldoodle
Post by ldoodle » Wed Jan 06, 2010 1:01 pm
There's always one!
When doing 10's of discs in a row (leave it going I may add while doing something else), you don't religously sit there with your finger hovering over the shit key in preparation of inserting a disc :shock:
adrian
Post by adrian » Wed Jan 06, 2010 4:30 pm
Presumably you still need to insert each disc manually so you can't rip 10 discs in a row without interaction anyway.
That said, sorry for being overly picky, but I really dislike unneccessary interface bloat.
setarip_old
Post by setarip_old » Fri Jan 08, 2010 12:19 am
@ldoodle
Click on the following link:
http://support.microsoft.com/kb/967715
