Error message with Avatar 2D/3D Disc
Everything related to Blu-ray 3D and 3D MKV files
Z0001
Post by Z0001 » Sat Dec 29, 2012 8:38 am
Hi I get an error message when trying to make an mkv of either or both the 2D and 3D Avatar from an iso I created from my original disc using AnyDVDHD.
Any pointers?
Thanks very much!
This is the error message:
MakeMKV v1.7.9 win(x64-release) started
AACS directory not present, assuming unencrypted disc
Title #00002.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Subtitle stream #10 is identical to stream #5 and was skipped
Subtitle stream #11 is identical to stream #6 and was skipped
File 00852.mpls was added as title #0
Title #00001.mpls was skipped
Title 00851.mpls is equal to title 00852.mpls and was skipped
File 00804.mpls was added as title #1
Title #00194.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00803.mpls is equal to title 00852.mpls and was skipped
Title 00800.mpls is equal to title 00852.mpls and was skipped
Title #00202.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00853.mpls is equal to title 00852.mpls and was skipped
Title 00850.mpls is equal to title 00852.mpls and was skipped
Title 00802.mpls is equal to title 00852.mpls and was skipped
Title 00854.mpls is equal to title 00804.mpls and was skipped
Title 00801.mpls is equal to title 00852.mpls and was skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory O:/Video/mkv/Movies/Avatar
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47220774912, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47221972992, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47224332288, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47223515136, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47228264448, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47250438144, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47234107392, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47253485568, attempting to work around
Failed to save title 0 to file O:/Video/mkv/Movies/Avatar/Avatar_t00.mkv
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47220314112, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47224725504, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47230255104, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47250475008, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 47253823488, attempting to work around
Failed to save title 1 to file O:/Video/mkv/Movies/Avatar/Avatar_t01.mkv
0 titles saved, 2 failed
Smithcraft
Re: Error message with Avatar 2D/3D Disc
Post by Smithcraft » Sat Dec 29, 2012 9:48 am
Does this happen when working with the original disc?
SC
setarip_old
Post by setarip_old » Sat Dec 29, 2012 8:41 pm
@Z0001
Hi!
Re-rip your original Blu-ray disc using ONLY MakeMKV (No need to use either AnyDVDHD or similar)...
cncb1
Post by cncb1 » Tue Jan 01, 2013 5:15 pm
This is supposed to be fixed in the next version: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=5529
