Brave DVD audio sync issue
chuga
Post by chuga »
I am having trouble getting a good quality rip of the Brave DVD. I ripped it using DVDFab (newest version) to Video_TS folder. When I play this folder using MPC-HC it seems OK.
Then I use makemkv to convert to a .mkv file. When playing this file with MPC-HC at some point the audio becomes out of sync with video.
I have tried re-ripping a few times with DVD Fab, and re-creating with makemkv but can't fix the issue.
Any suggestions??
thanks for the help
chuga
crowfax
Re: Brave DVD audio sync issue
Post by crowfax »
Don't rip with DVDfab first.
chuga
Post by chuga »
If you rip directly with MakeMKV do you have to run anydvd or something in the background?
I had issues trying to rip some DVDs with MakeMKV....for example Beauty and the Beast - you get all of these different main tracks with different angles to choose from. DVDFab seems to pick the correct track.
thanks!
setarip_old
Post by setarip_old »
Absolutely not...
