I am having trouble getting a good quality rip of the Brave DVD. I ripped it using DVDFab (newest version) to Video_TS folder. When I play this folder using MPC-HC it seems OK.
Then I use makemkv to convert to a .mkv file. When playing this file with MPC-HC at some point the audio becomes out of sync with video.
I have tried re-ripping a few times with DVD Fab, and re-creating with makemkv but can't fix the issue.
Any suggestions??
thanks for the help
chuga
Brave DVD audio sync issue
crowfax
Re: Brave DVD audio sync issue
Don't rip with DVDfab first.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
chuga
If you rip directly with MakeMKV do you have to run anydvd or something in the background?
I had issues trying to rip some DVDs with MakeMKV....for example Beauty and the Beast - you get all of these different main tracks with different angles to choose from. DVDFab seems to pick the correct track.
thanks!
thanks!
setarip_old
Absolutely not...If you rip directly with MakeMKV do you have to run anydvd or something in the background?
