Dark Knight Rises, Avatar 3d & Ice Age 4
barboot
Post by barboot » Thu Dec 13, 2012 12:43 am
Hello All
Having problems with all of the above mentioned Blu Rays.
I am getting the same error on all three which is below.
Has anyopne else had this?
Thank you for the help.
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00511.m2ts' at offset '2746368'
Error 'Internal error - Operation result is incorrect (204)' occurred while reading '/BDMV/STREAM/00511.m2ts' at offset '11298816'
Failed to save title 1 to file F:/BD Movies/Ice_Age_4_t01.mkv
0 titles saved, 1 failed
Smithcraft
Re: Dark Knight Rises, Avatar 3d & Ice Age 4
Post by Smithcraft » Thu Dec 13, 2012 1:42 am
How old is the drive?
SC
barboot
Post by barboot » Thu Dec 13, 2012 2:02 am
Hi
Only 1 year old.
Its an LG super multi bd/dvd writer
Should i look at another drive maybe?
Thank you.
setarip_old
Post by setarip_old » Thu Dec 13, 2012 2:24 am
Hi!
I think that would be a good idea...
barboot
Post by barboot » Thu Dec 13, 2012 2:26 am
ok thanks i will give that a try.
Thanks again for the help.
HolgiB
Post by HolgiB » Sat Dec 15, 2012 7:57 pm
barboot,
prior getting another drive, you should probably try another BD ripping software (e.g. DVDFab Bluray Copy, AnyDVD HD).
I own an external brand new LG BD burner myself and during my experients I found several BDs causing similar error plus others (e.g. dying MakeMKV console app).
AnyDVD HD was capable of cleanly ripping the BDs in the same drive, so i rather suspect a MakeMKV issue. MakeMKV worked fine for me on most of my BDs though.
HTH,
Holger
Romansh
Post by Romansh » Sat Dec 15, 2012 8:14 pm
When having issues ripping directly to MKV, I find that doing a full-disc backup and then creating the MKV(s) from that backup sometimes helps, too.
HolgiB
Post by HolgiB » Sat Dec 15, 2012 8:24 pm
I can only second this. I was not able to process the BD set for the Alien Anthology but could dump them to ISO with AnyDVD HD without issues.
To me it seems that the win-win combination here is AnyDVD HD and MakeMKV despite the warnings MakeMKV issues when you access a BD through the decryption layer of AnyDVD.
Romansh
Post by Romansh » Sat Dec 15, 2012 8:53 pm
Just to clarify, I meant a full disc backup with MakeMKV, rather than AnyDVD (which I do also have, but only use for DVDs nowadays). It often works, even when MakeMKV can't create an MKV file direct from disc.
Plus, MakeMKV can use BD hash checks to make sure the rip is fine (I've occasionally had issues when playing and/or re-encoding AnyDVD's ISO output).
barboot
Post by barboot » Thu Dec 20, 2012 1:54 am
Thanks guys, i will try all of those options first.
Thank you again for all the help.
