This is the error I see when using dvdbackup on these disks:
libdvdread: Elapsed time 0
*** Zero check failed in /build/buildd/libdvdread-4.2.0/src/ifo_read.c:574
for vmgi_mat->zero_6 = 0x0000000900000000000000000000000000000000000000000000000000000000
DVD-Video information of the DVD with title DOWNTON_ABBEY_S2_D2
MakeMKV v1.7.9 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dale/MakeMKV_log.txt
Title #0 was added (9 cell(s), 1:06:58)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #2 was added (6 cell(s), 0:53:00)
Title #3 was added (6 cell(s), 0:53:17)
Title #4 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:25:05)
Title #9 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 10551311 at ~u2`1]m17#]'S!5):213137712
DEBUG: Code 0 at ~u2`1]m17#]'S!5):213138885
DEBUG: Code 0 at ,'M,S*u#`2|XV> 0'<:29394597
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 12-12 were removed from title end
Title #10 was added (10 cell(s), 0:54:23)
Cells 2-end were skipped due to cell commands (structure protection?)
DEBUG: Code 233 at cAV6A1v3X+j5kQG7P8uioyvy:0
Saving 5 titles into directory /home/dale/Videos/DOWNTON_ABBEY_S2_D1
AV synchronization issues were found in file '/home/dale/Videos/DOWNTON_ABBEY_S2_D1/title00.mkv' (title #1)
AV sync issue in stream 1 at 0:00:39.039 with duration of 31ms : short audio gap was removed, audio skew is -31ms
AV sync issue in stream 1 at 1:06:59.071 with duration of 41.733ms : audio gap - 1.304 missing frame(s)
AV synchronization issues were found in file '/home/dale/Videos/DOWNTON_ABBEY_S2_D1/title01.mkv' (title #2)
AV sync issue in stream 1 at 0:53:01.888 with duration of 57.433ms : audio gap - 1.794 missing frame(s)
AV synchronization issues were found in file '/home/dale/Videos/DOWNTON_ABBEY_S2_D1/title02.mkv' (title #3)
AV sync issue in stream 1 at 0:53:16.993 with duration of 1.8ms : short audio gap was removed, audio skew is -1.8ms
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '16750592'
DEBUG: Code 0 at =)!xW$2GLc_`Gko{:2#/:121262739
DEBUG: Code 0 at 5}AqwEuLWF30qg/,!9.:121261681
DEBUG: Code 0 at =)!xW$2GLc_`Gko{:2#/:213130743
DEBUG: Code 8179 at =)!xW$2GLc_`Gko{:2#/:29393332
DEBUG: Code 0 at DGPg)}\ ZD(qEhxu:QZ\z:29398300
DEBUG: Code 0 at qp]sTx~5o-;gx)$t<Uw:121263935
Failed to save title 3 to file /home/dale/Videos/DOWNTON_ABBEY_S2_D1/title03.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '16613376'
DEBUG: Code 8112 at =)!xW$2GLc_`Gko{:2#/:29393332
Failed to save title 4 to file /home/dale/Videos/DOWNTON_ABBEY_S2_D1/title04.mkv
3 titles saved, 2 failed
