[Solved]Tearing in the picture, when copy from DVD
pettergulbra
#1 Post by pettergulbra » Tue Dec 04, 2012 12:00 am
Hi
I have used MakeMKV to copy my new DVDs with Friends.
But I get a strange problem in the picture, sound and everything else is OK.
I get lines all over the picture. If there is movements it gets fussy..
Like this:
I have not done any adjustments to the program, and the version is: 1.7.9
Hope someone can help me?
kindly
Petter
setarip_old
Re: Tearing in the picture, when copy from DVD
#2 Post by setarip_old » Tue Dec 04, 2012 12:22 am
Hi!
Have you played the ORIGINAL disc on the same system that you used for your screencap? If so, does it exhibit the same ghosting (perhaps interlacing)?
pettergulbra
#3 Post by pettergulbra » Tue Dec 04, 2012 12:39 am
That I have done, and there are not the same problem when I play directly from the DVD.
And the problem is the same on any player. (XBMC, VLC and WMP)
setarip_old
#4 Post by setarip_old » Tue Dec 04, 2012 12:47 am
Do any other DVDs exhibit the same anomalous behavior?
pettergulbra
#5 Post by pettergulbra » Tue Dec 04, 2012 12:52 am
Never seen this on any movie I have at all, this is the first time.
Not from original DVDs or from other files.
Edit: If I use Clone DVD, this don`t happen, but I don`t want it as DVD`s, I want each episode as an single file.
Like it better that way.
setarip_old
#6 Post by setarip_old » Tue Dec 04, 2012 4:26 pm
And are you SELECTING each individual episode (perhaps 22 minutes each) or are you selecting a "Play ALL" title (perhaps more than one hour)?
crowfax
#7 Post by crowfax » Tue Dec 04, 2012 7:33 pm
Dear god you're making this complex.
What you're seeing is very common on american DVD's, it's called interlacing. It's a quick and dirty way for DVD makers to turn video shot at 23fps to 29fps.
In your playback software, turn on deinterlacing. Your DVD player does it by default, your playback software does not.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
setarip_old
#8 Post by setarip_old » Wed Dec 05, 2012 12:40 am
@crowfax
Hi! You say
How do you account for the fact that the OP states that when he/she plays the ORIGINAL DVD with the same software players, they DON'T exhibit interlacing or "ghosting"?
pettergulbra
#9 Post by pettergulbra » Wed Dec 05, 2012 12:51 am
setarip_old wrote:
@crowfax
Hi! You say
My question to.
I use the same PC and same software to play the files, before and after ripping.
As said over, DVD`s is just fine. The MKV isn`t.
crowfax
#10 Post by crowfax » Wed Dec 05, 2012 7:16 am
The source material (the DVD) is interlaced. I don't have answers as to why your software is deinterlacing by default from the DVD and not when playing a file. Use SMplayer or VLC, turn on deinterlacing and the issue will be gone.
If either of you need more information then you can read about it here: http://www.100fps.com/.
I have nothing else to say on the issue. You don't have to take my advice, you can open up VLC and turn on deinterlacing and see that I'm right, or you can keep asking why this is happening on a forum and make no progress.
pettergulbra
#11 Post by pettergulbra » Wed Dec 05, 2012 2:35 pm
crowfax:
It seems like your right. I haven`t tested much yet, but I will. And come back to this.
If it helps, I hope XBMC have the same options to put this on/off.
paulster
#12 Post by paulster » Wed Dec 05, 2012 7:48 pm
Material originally shot on video rather than film, so mostly for TV, will often be interlaced because it was intended to be broadcast, which would have required it to be interlaced at that point. DVDs have always been able to store interlaced or progressive content, so they put it on there as it was.
pettergulbra
#13 Post by pettergulbra » Wed Dec 05, 2012 8:31 pm
Thanks for the help! :-)
It worked so I don`t have to rip it again. My life is saved.
Thanks again. It was a simple solution, but i diden`t know about it.
crowfax
Re: [Solved]Tearing in the picture, when copy from DVD
#14 Post by crowfax » Thu Dec 06, 2012 4:17 am
You're welcome, I'm glad I saved you hours of pointless troubleshooting.
