Problem with Blu-ray Disc
ematthys
Post by ematthys » Tue Jan 05, 2010 6:11 am
I am having problems with a particular blu-ray disc that I have not encountered before.
I get the following error after it tries to make the mkv out of the largest track on the disc:
"Copy Complete. 0 titles saved, 1 failed."
Here is the output window:
MakeMKV v1.4.10 beta darwin(x86-release) started
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occured while reading 'BD-ROM PLEXTOR BDDVDR PX-B310U 1.05' at offset '24689965056'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '00024.m2ts' at offset '58515456'
File 00047.mpls was added as title #0
File 00062.mpls was added as title #1
Title #00074.mpls has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00075.mpls was added as title #2
Title #00076.mpls has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00080.mpls was added as title #3
File 00081.mpls was added as title #4
Title #00082.mpls has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00083.mpls was added as title #5
Title #00003.mpls has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.mpls was added as title #6
Title 00007.mpls is equal to title 00006.mpls and was skipped
Title 00008.mpls is equal to title 00006.mpls and was skipped
Title 00009.mpls is equal to title 00006.mpls and was skipped
Title 00010.mpls is equal to title 00006.mpls and was skipped
Title 00011.mpls is equal to title 00006.mpls and was skipped
Title 00012.mpls is equal to title 00006.mpls and was skipped
Title 00013.mpls is equal to title 00006.mpls and was skipped
Title 00014.mpls is equal to title 00006.mpls and was skipped
Title 00015.mpls is equal to title 00006.mpls and was skipped
Title 00016.mpls is equal to title 00006.mpls and was skipped
Title 00017.mpls is equal to title 00006.mpls and was skipped
Title 00018.mpls is equal to title 00006.mpls and was skipped
Title 00019.mpls is equal to title 00006.mpls and was skipped
Title 00020.mpls is equal to title 00006.mpls and was skipped
Title 00021.mpls is equal to title 00006.mpls and was skipped
Title 00022.mpls is equal to title 00006.mpls and was skipped
Title 00023.mpls is equal to title 00006.mpls and was skipped
Title 00024.mpls is equal to title 00006.mpls and was skipped
Title 00025.mpls is equal to title 00006.mpls and was skipped
Title 00026.mpls is equal to title 00006.mpls and was skipped
Title 00027.mpls is equal to title 00006.mpls and was skipped
Title 00028.mpls is equal to title 00006.mpls and was skipped
Title 00029.mpls is equal to title 00006.mpls and was skipped
Title 00030.mpls is equal to title 00006.mpls and was skipped
Title 00031.mpls is equal to title 00006.mpls and was skipped
Title 00032.mpls is equal to title 00006.mpls and was skipped
Title 00033.mpls is equal to title 00006.mpls and was skipped
File 00043.mpls was added as title #7
File 00071.mpls was added as title #8
File 00086.mpls was added as title #9
File 00087.mpls was added as title #10
File 00088.mpls was added as title #11
File 00089.mpls was added as title #12
File 00090.mpls was added as title #13
File 00091.mpls was added as title #14
File 00092.mpls was added as title #15
File 00093.mpls was added as title #16
File 00094.mpls was added as title #17
File 00097.mpls was added as title #18
File 00100.mpls was added as title #19
File 00055.m2ts was added as title #20
File 00063.m2ts was added as title #21
Title #00065.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00066.m2ts was added as title #22
File 00067.m2ts was added as title #23
Title #00069.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00072.m2ts was added as title #24
Title #00077.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory /Users/ematthys/Movies/HK2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00024.m2ts' at offset '61440'
Failed to save title 19 to file /Users/ematthys/Movies/HK2/title19.mkv
setarip_old
Re: Problem with Blu-ray Disc
Post by setarip_old » Tue Jan 05, 2010 8:33 am
Sounds like the disc is either dirty or damaged...
ematthys
Post by ematthys » Tue Jan 05, 2010 3:25 pm
Hmmmm... the disc has a couple small scratches, but nothing that I would think could interfere much...
Pepitto1963
Post by Pepitto1963 » Sun Jan 10, 2010 9:35 pm
I have something similar. My movie is on hard disk (DVDFab)
and has one audio stream and one subtitle.
MakeMKV v1.4.11 beta win(x64-release) started
Opening files on harddrive at E:/MainMovie/The Hangover/
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Saving 1 titles into directory D:/Videos
Failed to save title 0 to file D:/Videos/title00.mkv
setarip_old
Post by setarip_old » Mon Jan 11, 2010 6:58 am
@pepitto1963
Hi!
MakeMKV is perfectly capable of ripping your original BluRay disc by itself, without using any other software (such as DVDFab or AnyDVD).
I'd suggest you try using
ONLY MakeMKV to rip your original, commercial BluRay disc...
