"Host certificate revoked" - drive now useless?
mrjamin
#1 Post by mrjamin » Fri Jan 01, 2010 9:53 pm
Have successfully backed up a few BD titles with MakeMKV over the past couple of days, but now every attempt is failing, even with discs that previously worked fine.
What gives? Does this mean my drive is no longer usable for BD titles?
I've rebooted (soft restart, as well as power off and power on again) and the problem persists.
I'm running Ubuntu 9.10 (i686 - 2.6.31-16-generic kernel), here's the some debug output:
$ makemkvcon info disc:0
001014:000000:0000 MakeMKV v1.4.10 beta linux(x86-release) started
Current action: Scanning CD-ROM devices
003010:000000:0000 Using direct disc access mode
Current action: Pre-calculating data
Current action: Processing AV clips
Current action: Processing movie playlists
Current action: Decrypting
002014:000000:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command to device 'SG:dev_11:0'
002014:000000:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command to device 'SG:dev_11:0'
003311:000000:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
005010:000000:0000 Failed to open disc
Total 0 titles
dmesg has the following to say about my drive (snipped for brevity!):
ATAPI: BDROM-400, 1029, max UDMA/100
CD-ROM BDROM-400 1029 PQ: 0 ANSI: 5
sr0: scsi3-mmc drive: 51x/51x cd/rw xa/form2 cdda tra
Uniform CD-ROM driver Revision: 3.20
sr 3:0:0:0: Attached scsi CD-ROM sr0
sr 3:0:0:0: Attached scsi generic sg1 type 5
Re: "Host certificate revoked" - drive now useless?
#2 Post by mike admin » Sun Jan 03, 2010 7:47 am
This should have been caused by sobe BD disc you've inserted recently, not necessary even open with MakeMKV. I would ask you to send a file named MKB_RO.inf from this disc to support@makemkv.com . If you are not sure which one caused this, send this file from multiple discs. These files compress really well. Once we have the file we'll update MakemKV and your drive will start working again. Thank you.
mrjamin
#3 Post by mrjamin » Mon Jan 04, 2010 10:22 am
Hey thanks, will fish it out tonight. I expect it's a v.recent release: "Take That - The Circus Live"
