Expendables 2
Dilligaf
Expendables 2
#1 Post by Dilligaf » Thu Nov 29, 2012 9:31 pm
hi after using mkv to do full decrypt back up of the movie when playing in my sony s470 player im getting this is a copy and is not allowed to play just want to know if any one else having this problem thanks
setarip_old
Re: Expendables 2
#2 Post by setarip_old » Fri Nov 30, 2012 3:06 pm
Hi!
As "mike admin" has previously replied many times to me and others, although it may be successfully used with many "simpler" Blu-ray discs, MakeMKV is not (presently) a tool for performing properly ripped FULL DISC Blu-ray backups.
It will, however, properly perform MOVIE-ONLY backups.
For a movie-only rip of Expendables2:
(From what I've read elsewhere) Try either MPLS 609 or 684 (May be for purchased versions or other versions)...
Dilligaf
Re: Expendables 2
#3 Post by Dilligaf » Fri Nov 30, 2012 9:09 pm
thank i did use 684 but no luck with it and i dont have a MPLS 609
setarip_old
Re: Expendables 2
#4 Post by setarip_old » Fri Nov 30, 2012 11:12 pm
Is your source material an original, commercial Blu-ray?
Dilligaf
Re: Expendables 2
#5 Post by Dilligaf » Sun Dec 02, 2012 1:36 am
it was a rental
setarip_old
Re: Expendables 2
#6 Post by setarip_old » Sun Dec 02, 2012 7:29 pm
it was a rental
Discussion of commercial media that you haven't purchased or don't own is not acceptable at the MakeMKV forum (and some other forums as well)...
