MKV audio only possible?
Glenmorangie
Post by Glenmorangie » Thu Nov 29, 2012 10:38 pm
Dear all,
one question from a beginner: just read in several boards about MakeMKV and what I need as a tool:
I want to extract the DTS HD music quality our of my BluRays and store this quality in MKV files which are using FLAC as music codec.
I do not want to have any video in the MKV file to have a smaller file.
So for me the MKV container would only be the "transporter" for the Hi-Res FLAC data.
Is this possible? If yes how?
At the moment I select only the DTS stream (no video) and the FLAC profile. When pressing the button I get the message: no data selected...
Looking forward to your answers
Glenmorangie
Re: MKV audio only possible?
Post by Woodstock » Fri Nov 30, 2012 4:18 am
I suspect that the issue is that MakeMKV is assuming that, since you're using Matroska video format file, you would want the video... :)
You can let MakeMKV create the MKV file, then use tools like mkvmerge to extract just the track(s) you want into your "final" file.
Glenmorangie
Post by Glenmorangie » Fri Nov 30, 2012 11:11 pm
Thanks Woodstock,
wonderful idea!
I used MKVMerge in the past to bring sound and image together so I gave it a try and it worked perfectly!!!
MKV Container is now "small" and still playable...
THX for your help
Glenmorangie
