Sorry - Tried to do things on my own without help - stuck
atsig
Post by atsig » Thu Nov 29, 2012 2:22 am
I have been at this for 5 days. If it helps I have the following:
OSX 10.7.5
2x 2.66 Dual core Xion
LG external Blueray
I have never successfully made a MKV from this app. Here is my last attempt. I am very hopeful someone could give me guidance.
Sorry for the long detail. I'm not sure what is important.
MakeMKV v1.7.9 darwin(x86-release) started
Optical drive "DVD+R-DL HP DVD Writer 630c CH16" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE BP40NS20 ML01" opened in DASPI v1.3 mode.
Evaluation version, 25 day(s) out of 30 remaining
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00046.m2ts' at offset '45232128'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00047.m2ts' at offset '8128512'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '194789376'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00204.m2ts' at offset '49158144'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00121.m2ts' at offset '288768'
File 00035.mpls (angle 1) was added as title #0
File 00035.mpls (angle 2) was added as title #1
File 00035.mpls (angle 3) was added as title #2
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00119.m2ts' at offset '651264'
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Title #00045.mpls was skipped
File 00158.mpls was added as title #3
File 00190.mpls was added as title #4
File 00198.mpls was added as title #5
File 00199.mpls was added as title #6
Title #00108.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00148.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00161.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00164.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00166.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00176.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00177.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00178.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00187.m2ts was added as title #7
Title #00188.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00189.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00197.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00198.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00199.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00201.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.m2ts was added as title #8
File 00211.m2ts was added as title #9
File 00212.m2ts was added as title #10
File 00214.m2ts was added as title #11
Title #00215.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00239.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/aaron/Desktop
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '325632'
Profile parsing error: Specified conversion filter (68:A_MS/ACM->LPCMwavex) is not available
Failed to save title 0 to file /Users/atsig/Desktop/title00.mkv
0 titles saved, 1 failed
Re: Sorry - Tried to do things on my own without help - stuc
Post by Woodstock » Thu Nov 29, 2012 4:00 am
The operating system said that the request to read that sector didn't work. There is probably a flaw in the disk.
Have you cleaned it?
atsig
Post by atsig » Thu Nov 29, 2012 4:11 am
I will clean it and try again. thank you for your help.
