bluray errors more common
sdvidiot
Post by sdvidiot » Mon Nov 26, 2012 5:36 am
I'm a longtime registered makemkv user. I've been experiencing more and more errors while ripping BD. While attempting to rip a brand new disc I get this error message: (note: the disc is clean and plays in my regular bluray player)
Saving 1 titles into directory V:/Drama/Albert Nobbs (2011)
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001003:0020 DEBUG: Code 3221225628 at mq\,.f)p,QjJ6;.T%9'm|=)eY:121263521
001003:0020 DEBUG: Code 3221225628 at 8/9='T0'F`f$E(>~:29393953
001003:0020 DEBUG: Code 2 at 'KiOubJK,?YleKtl:121268719
002003:0000 Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '17293178880'
001003:0020 DEBUG: Code 0 at RF\uby:WGPwFGJ1k5:29396667
001003:0020 DEBUG: Code 0 at RF\uby:WGPwFGJ1k5:213131686
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 2 to file V:/Drama/Albert Nobbs (2011)/Albert_Nobbs_t02.mkv
005004:0080 0 titles saved, 1 failed
setarip_old
Re: bluray errors more common
Post by setarip_old » Tue Nov 27, 2012 5:43 pm
Hi!
Although the discs may be clean, it's possible that your reader/burner is either failing or in need of cleaning with a cleaning disc. Maxell makes one that sells for about $10US...
sdvidiot
Post by sdvidiot » Tue Nov 27, 2012 6:25 pm
I will give that a try. However, do the above error logs suggest that may be the issue?
crowfax
Post by crowfax » Tue Nov 27, 2012 7:24 pm
Means your drive reported an error when reading the disc. More specifically I think it means the laser skipped because the surface of the disc was imperfect.
sdvidiot
Post by sdvidiot » Fri Nov 30, 2012 10:53 pm
I used a bluray cleaning disc and the problem is not resolved. D'oh!
Post by Woodstock » Sun Dec 02, 2012 4:35 am
If cleaning the drive did not fix the situation, AND the drive is getting these seek errors on multiple disks, there is a very good chance that the drive itself is failing. When commanded to go to particular sectors on the disk, it can't find them.
Are ANY of your BDs readable by this drive? Are the failures occurring around the same range of sector counts? How does the drive do with a DVD?
