All Rips Fail After Windows 8 Install
First I'd like to say that I love the program. I registered quite some time ago and I've had zero issues with 100's of previous rips.
After upgrading my legit W7 install to a legit W8 install, both DVD and Blu-Ray fail 100% of the time. I have attempted to re-rip disks I'd ripped in the past without issue and those failed as well.
I've entered my key, as well as the current beta key. I've uninstalled via advanced Revo uninstall and re-installed with the same result. I've checked to see if my Lite-On BR drive needed a firmware update and it is up to date.
I am experiencing no other system instability and have watched DVD's from the drive in WMC 8.
Any troubleshooting advice would be greatly appreciated. I am at a loss.
Below is a log from Batman Begins which I've successfully ripped in the past with MakeMKV.
MakeMKV v1.7.9 win(x64-release) started
Title #00013.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00022.mpls was added as title #0
Title #00024.mpls has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.mpls has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.mpls has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00031.mpls was added as title #1
Title #00032.mpls has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.mpls was added as title #2
Title #00050.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00072.mpls was added as title #3
File 00057.mpls was added as title #4
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #5
Title #00001.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00016.m2ts was added as title #6
File 00017.m2ts was added as title #7
File 00018.m2ts was added as title #8
File 00021.m2ts was added as title #9
File 00022.m2ts was added as title #10
File 00023.m2ts was added as title #11
File 00024.m2ts was added as title #12
File 00025.m2ts was added as title #13
File 00026.m2ts was added as title #14
File 00027.m2ts was added as title #15
Title #00003.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00120.m2ts was added as title #16
Title #00121.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory G:/Movies 2/Batman_Begins
The source file '/BDMV/STREAM/00051.m2ts' is corrupt or invalid at offset 2666496, attempting to work around
1 titles saved
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 322301952, attempting to work around
Failed to save title 2 to file G:/Movies 2/Batman_Begins/title02.mkv
0 titles saved, 1 failed
1 titles saved
Re: All Rips Fail After Windows 8 Install
That has nothing to do with Windows 8. That's just a bad disc.
Maybe you skipped some of my post. I wish the disks I've attempted were in poor condition as that would explain it. However, the disks are flawless as when they are brand new their first stop is the HTPC then storage. At this point disk condition can be ruled out. I've tried about 15 different disks with 100% failed.
Ok, let me rephrase then....MakeMKV works perfectly fine for me on Windows 8 as I just got done ripping a movie with it about an hour ago. If you look at the log you posted, you'll see a whole bunch of read errors. It's quite fine if you don't want to take my word for it. You can wait for others to give you a better answer that you like.
I wasn't for a second suggesting that MakeMKV is incompatible with Windows 8. I am asking for help in hopes that another user experienced some similar hiccup after they installed W8. Glad your install and most others installs are working well. I'm looking forward to rejoining those ranks.
Yea, not sure what's going on with your install. Very strange if it's not a bad disc. Does the disc play on that system without problem?
I don't have BluRay playback software on this build but I've confirmed DVD's that played perfectly won't rip with MakeMKV errors logs that look just like this one I posted above.
Try using the full disc rip option and see if that works at all.
Naturally the titles that saved were not the actual movie. This disk plays fine on the system.
Saving 1 titles into directory G:/Movies 2/How The Grinch Stole Christmas
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279052288, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279054336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279056384, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279058432, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279060480, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279062528, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279064576, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279066624, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279068672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279070720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279072768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279074816, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279076864, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279078912, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279080960, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279083008, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279085056, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279087104, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279089152, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279091200, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279093248, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279095296, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279097344, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279099392, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279101440, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279103488, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279105536, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279107584, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279109632, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279111680, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279113728, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279115776, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279117824, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279119872, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279121920, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279123968, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279126016, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279128064, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279130112, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279132160, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279134208, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279136256, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279138304, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279140352, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279142400, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279144448, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279146496, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279148544, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279150592, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279152640, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279154688, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279156736, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279158784, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279160832, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279162880, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279164928, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279166976, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279169024, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279171072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279173120, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279175168, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279177216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279179264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 279181312, attempting to work around
Failed to save title 0 to file G:/Movies 2/How The Grinch Stole Christmas/HOW_THE_GRINCH_STOLE_CHRISTMAS_t00.mkv
Saving 7 titles into directory G:/Movies 2/How The Grinch Stole Christmas
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105250816, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105252864, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105254912, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105256960, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105259008, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105261056, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105263104, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105265152, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105267200, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105269248, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105271296, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105273344, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105275392, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105277440, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105279488, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105281536, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105283584, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105285632, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105287680, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105289728, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105291776, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105293824, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105295872, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105297920, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105299968, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105302016, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105304064, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105306112, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105308160, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105310208, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105312256, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105314304, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105316352, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105318400, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105320448, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105322496, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105324544, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105326592, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105328640, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105330688, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105332736, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105334784, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105336832, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105338880, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105340928, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105342976, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105345024, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105347072, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105349120, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105351168, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105353216, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105355264, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105357312, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105359360, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105361408, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105363456, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105365504, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105367552, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105369600, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105371648, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105373696, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105375744, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105377792, attempting to work around
The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 105379840, attempting to work around
Failed to save title 1 to file G:/Movies 2/How The Grinch Stole Christmas/HOW_THE_GRINCH_STOLE_CHRISTMAS_t01.mkv
Failed to save title 2 to file G:/Movies 2/How The Grinch Stole Christmas/HOW_THE_GRINCH_STOLE_CHRISTMAS_t02.mkv
Track #2 turned out to be empty and was removed from output file
Failed to save title 5 to file G:/Movies 2/How The Grinch Stole Christmas/HOW_THE_GRINCH_STOLE_CHRISTMAS_t05.mkv
3 titles saved, 4 failed
There are a couple of other threads on here about problems with Win8. It seems that one or more DLLs that are necessary are not properly registered unless the install is done "just so". In some cases, simply doing the install and running with administrator privileges will fix it.
One of the other threads discussing it is here, and has links to solutions on other forums. It isn't JUST MakeMKV that is having problems with Win8!
Thanks Woodstock, I should have mentioned that I also ran as Admin with no luck. I've also now reverted to an older version of MakeMKV with the same failures. I hate to even ask here, but is there an alternative to MakeMKV that I might use in the meantime?
Okay, on v1.7.6 run as Administrator I had my first successful rip. Gotta love backups! Guess I hold off a while on any updates.
MakeMKV v1.7.6 win(x64-release) started
The new version 1.7.9 is available for download at http://www.makemkv.com/download
Title #0 was added (1 cell(s), 0:25:40)
Title #1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (1 cell(s), 0:15:47)
Title #10 was added (1 cell(s), 0:19:17)
Title #11 was added (2 cell(s), 0:08:02)
Title #12 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (4 cell(s), 0:03:02)
Title #14 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 was added (3 cell(s), 0:03:15)
Title #19 was added (4 cell(s), 0:03:25)
Title #20 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
1 titles saved
1 titles saved
That's a whacked problem with the w8 installs. Guess I missed that. I just clean installed my main htpc to upgrade to w8 and haven't had any issues with makemkv. Apparently I was lucky! Good info to know though.
Wait I just read what you wrote here more carefully. You say you ran as administrator... But did you run the installer as administrator? That's what Woodstock was alluding to in their post.A_Shields wrote:Thanks Woodstock, I should have mentioned that I also ran as Admin with no luck. I've also now reverted to an older version of MakeMKV with the same failures. I hate to even ask here, but is there an alternative to MakeMKV that I might use in the meantime?
