Dolby Digital Plus 7.1 - Merida (Brave) Blu-ray
dt2510
#1 Post by dt2510 » Tue Nov 20, 2012 10:39 am
I have some problems ripping the german "Merida" (Pixar's "Brave") Blu-ray. Analyzing the m2ts files with MediaInfo, i found the following audio track:
Audio #5
Men?-ID                                  : 1 (0x1)
Format_Settings_ModeExtension            : CM (complete main)
Format-Einstellungen f?r Endianess       : Big
Muxing-Modus                             : Stream extension
Codec-ID                                 : 132
Dauer                                    : 45s 120ms
Bitraten-Modus                           : konstant
Bitrate                                  : 512 Kbps
Kan?le                                   : 6 Kan?le
Kanal-Positionen                         : Front: L C R, Side: L R, LFE
Samplingrate                             : 48,0 KHz
BitDepth/String                          : 16 bits
Stream-Gr??e                             : 2,75 MiB (1%)
Using MakeMKV 1.7.9 x64 the track is recognized as "DDplus 3/1 German". After ripping the above audio track appears in MediaInfo like this:
Audio #1
Format                           : E-AC-3
Format/Info                      : Audio Coding 3
Codec-ID                         : A_EAC3
Dauer                            : 1h 34min
Bitrate                          : 384 Kbps
Kan?le                           : 4 Kan?le
Stream-Gr??e                     : 259 MiB (1%)
Sprache                          : Deutsch
All other tests using tsmuxer or mkvmerge also had no success in correctly ripping the E-AC3 audio. Any ideas ?
Romansh
Re: Dolby Digital Plus 7.1 - Merida (Brave) Blu-ray
#2 Post by Romansh » Tue Nov 20, 2012 12:04 pm
Dolby Digital Plus sometimes has an embedded "core" (typically, 5.1 channels, but in your case, 4.0). Some tools and decoders can only parse/decode that core, and not the additional channels.
#3 Post by mike admin » Wed Nov 21, 2012 9:16 am
Interesting. Please make and send the test dump for this title per instructions at http://www.makemkv.com/onlinehelp/testdump.html
Romansh
#4 Post by Romansh » Wed Nov 21, 2012 11:16 am
I had obviously read your post too fast. Not sure how the "core" went from 5.1 to 4.0 channels…
